wtf Harley Davidson
Old Jan 20, 2014 | 05:34 PM
MrGood's Avatar
MrGood
Default wtf Harley Davidson
This is the second time now I have ordered the cable kit 32184-08A which is pictured as a 6 pin type plug and I've received a 4 pin which will not work with my '14 iron despite it saying '01 and up and three stealer employees telling me it will work. I'm going on week two that I haven't been able to ride because I don't want to run it lean with my new exhaust and heavy breather. Does anyone know where I can get the right cable to work with the SE pro super tuner and a 2014 sportster?
Old Jan 20, 2014 | 07:04 PM
John Harper's Avatar
John Harper
I believe there are some substantial changes in the 2014 model. The wiring system has been changed, as well as the exhaust (Cat converters).
I doubt many people on this forum have a 2014 model. So you might be a bit premature on getting upset. Even the dealers are probably misinformed.
Relax, it will all work out. You could be living in Colombia like Mike LaPlaya, and be totally buggered.
Or, put your stock AC back on and go for a ride. It really clears your mind.
John
Old Jan 20, 2014 | 08:09 PM
Stitches1974's Avatar
Stitches1974
O2 sensors have been moved. Rear brake cylinder is on the right rear passenger peg bracket. Tach / gear position indicator is built into the factory speedo, finally. In addition to the changes mentioned above.
I have a 2014 1200C should have it delivered this week sometime.
Old Jan 20, 2014 | 11:22 PM
1HDRIO's Avatar
1HDRIO
Originally Posted by Stitches1974
O2 sensors have been moved. Rear brake cylinder is on the right rear passenger peg bracket. Tach / gear light is built into the factory speedo, finally. In addition to the changes mentioned above.
So that tach-looking light with an arrow is the gear light? I have a 2014 48 and was wondering about it on my speedo...
Old Jan 21, 2014 | 08:08 AM
Stitches1974
There's a button on the left handle bar that you press to scroll through trip, clock etc on the LCD screen. One of the settings is rpm/gear position. Sorry I shouldn't have used gear light in my last post. I should have posted gear position.
Old Jan 21, 2014 | 09:06 AM
MrGood's Avatar
MrGood
Originally Posted by John Harper
I believe there are some substantial changes in the 2014 model. The wiring system has been changed, as well as the exhaust (Cat converters). I doubt many people on this forum have a 2014 model. So you might be a bit premature on getting upset. Even the dealers are probably misinformed. Relax, it will all work out. You could be living in Colombia like Mike LaPlaya, and be totally buggered. Or, put your stock AC back on and go for a ride. It really clears your mind. John
I realize things are different. This is a shitty picture of a printed out picture of what's shown on the website that I have ordered twice. It is the correct plug.
This is what I got for the second time now. It is the wrong plug despite having the part number of the correct one on the website that clearly states "fits 2014 iron 883 xl883n"
Old Jan 21, 2014 | 03:01 PM
1HDRIO's Avatar
1HDRIO
Attachment 353773
Attachment 353774
MrGood,
I hope you get the correct wiring; I am also looking at getting the SE tuner however my dealer told me that the pro will void the warranty...
Old Jan 21, 2014 | 03:48 PM
MrGood's Avatar
MrGood
MrGood, I hope you get the correct wiring; I am also looking at getting the SE tuner however my dealer told me that the pro will void the warranty...
Depends on the dealer. Also the Harley website has bad info on it. The correct part number for the cable kit is. 41000018.
svshaw82
Panhead
18
Oct 27, 2021 05:45 PM
commander47
Sep 21, 2015 02:04 PM
OddJack
Mar 29, 2014 10:48 PM
pleasants9
May 6, 2011 05:04 AM
silverbullet2005
Jul 8, 2007 08:25 PM
