affraid to scrape!
I actually was taking a right turn at an intersection on my way to work and hit a pothole that broke the exhaust heat shield bracket (i.e. hose clamp).
I now have V&H Shortshots… if I’m dragging them, that means it’s on it’s side!
The KEY thing to remember is that the tires have plenty of grip at that point, so the last thing you want to do is panic and jerk the bars to get it more upright… that can be a natural reaction, but one that could cause bad things to happen.
- Jerm
I'm wondering...how do you scrape the kickstand (on a new bike) before you scrape the pegs?
So far only time I scraped was doing the Motormans exercises ....
dang ****** ...
I remember you posting a "minor" problem. How fast were you going ? Just wondering ... dat sure is alotta snapped bones. What kind of gear were you wearing ?
i forget who it was, but i remember reading in a post about a week ago that someone was riding with a buddy who stuck his forward control into the ground and didnt live to tell about it. no thanks.
That said....in regards to your original question, the turning ability of the Sportster is better than your old Roadstar. Greater lean angles are possible with a Sportster as opposed to a Roadstar.
Most of the discussion here surrounds getting the bike into some big angle leans. In almost all the cases the same holds true - parts on the bike will scrape pavement before you lose traction.
A thought to ponder is why you are scraping in the first place. If you are just testing the bike, putting it through its paces and such, that's one thing. But often you end up scraping because you get into a tight situation and have to make a decision.
Here's the scenario: You get into a turn and realize you are going too fast or not set up properly. You've got two options:
1.Lean harder, accelerate and push through.
2.Attempt to slow down; either right the bike and hard brake to reduce speed and then resume turn or try to reduce speed by either chopping the throttle or braking while still in your lean.
Option one is mentally counter-intuitive but likely has the greater chance of successfully making it through upright. Option two will result in upsetting the balance of the bike and you'll likely fall into the turn or you’ll push a lot of weight on the front wheel and it will push out from under you.
Parting thought: For normal riding where you find yourself accidentally scraping the exhaust or kickstand you can adjust your lean angle and probably be fine. A little is ok. Just don’t intentionally push the envelope.
Anyway, Looks like you're find and dandy now [sm=icon_cheers.gif]
If I scrape anything it's usually the heel of my boot - which tell me I'm close to scraping my pegs and lighten up. ******'s issue may be different though, I'd imagine there are circumstances that could cause problems but most pegs will move up with contact and not cause you to go down.
****** - so what happened to you?..care to share?
I ride Angeles Crest Highway North of Glendale, which is world famous for bikers (especially rice rockets) and you're guranteed to scrape up there. There's about 150 miles of intense mountain roads and corners up there and it's a blast to ride. If you ever find yourself in or near LA, check it out. It's the 2 Freeway North of Glendale.
1. Lean harder, accelerate and push through.
2. Attempt to slow down; either right the bike and hard brake to reduce speed and then resume turn or try to reduce speed by either chopping the throttle or braking while still in your lean."
Trail braking is important. My bike has plenty of lean angle. I try to live by simple rules, one being that I try not to scrape anything. Ireckon if I had wanted to get out there and drag a knee I'd have bought a Buell.
One comment you made could be misunderstood by beginners and that's the braking while turning. It's a tricky subject and something that you have to be very careful with, which is why all of the classes teach you not to brake in real corners. Braking during a low speed tight turn such as a parking lot is a different story, which is where the trail braking is essential. I just didn't want some of our new riders braking at 55MPH through an increasing radius turn and locking up one of their brakes and posting a week from now how they got busted up and their bike is in the shop.
