XL2008c Problem with codes
Old May 25, 2014 | 02:16 PM
Nemandza's Avatar
Nemandza
1st Gear
Default XL2008c Problem with codes
Just came a 2008 XL 1200c,and I cant start it. Red key appears on the spedo,as well as the code U1064. In S mode appears Pn 68920-07,and in SP mode Pn 67436-08. I tried to google it with no result. Can anybody tell me what does these codes and Pn`s mean?
Thanks!
Old May 25, 2014 | 02:24 PM
slyedog's Avatar
slyedog
You have the key fob? If so battery good? Sound like a security issue.
Old May 25, 2014 | 02:40 PM
Nemandza's Avatar
Nemandza
1st Gear
No key fob,and the battery is charged...
Old May 25, 2014 | 03:17 PM
Curt1953's Avatar
Curt1953
If the bike have security on it, you have to have the key fob with it to start the bike. I have the same bike.
Old May 25, 2014 | 03:41 PM
elfnyc's Avatar
elfnyc
the U code
U1064 Loss of TSM/FSFM Serial Data to ICM / ECM
U1064 Loss of TSM/TSSM Serial Data Instruments
TSM/TSSM (Turn Signal/ Turn Signal Security Module)
the pn
Those are not error codes, they are part numbers
pn 67436-08 speedo
Pn 68920-07 turn sig module
try clearing the U1064 code
and like they said u need the fob with u
check all your fuses
Usually it means that the modules in the system are not communicating with each other as in open wire somewhere. What have you done recently?
again check your fuses
Old May 25, 2014 | 05:30 PM
slyedog's Avatar
slyedog
Referring to battery in fob. The fob is where I would start. I thought there is a procedure if in an emergency to override it. Go online to Harley's website and you can view your owners manual to find out.
Old May 26, 2014 | 05:38 AM
Nemandza's Avatar
Nemandza
1st Gear
Originally Posted by elfnyc
the U code
the pn
pn 67436-08 speedo
Actually, I just got the bike,and since I cant start it,I havent done any mods. And the dealer didnt send me the fob. Can I start it without it?
And you re right, one fuse is always going bad...
I am going to the dealership tommorow.
Old May 26, 2014 | 05:06 PM
elfnyc's Avatar
elfnyc
u can start without the fob
if they didnt program it with a differ code already - u need to know the code to do it
unless it was never changed ..
Old May 27, 2014 | 01:20 PM
Nemandza's Avatar
Nemandza
1st Gear
Actually,it started without a for in a dealership. The problem was open wire in the start button. Thanks for your help guys!
Old May 27, 2014 | 05:38 PM
elfnyc's Avatar
elfnyc
ahh nice to know glad ya fixed it up
13_Lucky
Mar 9, 2014 04:26 PM
SD1
Jun 23, 2013 02:45 AM
ghoticov
Apr 27, 2013 05:11 PM
maintainin
Screamin Eagle CVO Models
Sep 5, 2012 02:00 AM
arachman
Jun 19, 2007 01:55 AM
