vibrations
Old Apr 6, 2007 | 10:22 AM
outdoorgirl57's Avatar
outdoorgirl57
Default RE: vibrations
Mine also vibrates a little more between 60-65 MPH...and then smoothes out when I get in the 70+ range. The aftermarket pipes definitely gave me a little more vibration at all speeds, but nothing annoying.
Old Apr 6, 2007 | 10:33 AM
GeorgiaGirl's Avatar
GeorgiaGirl
Madame Moderator
ORIGINAL: GAGirl
I noticed alot of vibration just in the pegs of my 2005 883 Sporty Custom at 70 and above unless I push the my boots hard against the pegs, but doing that makes it quite tolerable. Haven't had it up to 80 yet to see if it smooths out again, but do plan to test that. Sporties are more manueverable than the big twins but have to work at higher RPMs at those speeds hence the vibration and the way the engine is mounted.
Was doing some reading last night and am I correct that neither the Springers nor the Dyna's handle as well as the Sporties even?
Old Apr 6, 2007 | 06:45 PM
jwb47's Avatar
jwb47
ORIGINAL: GAGirl
I noticed alot of vibration in my 2005 883 Sporty Custom at 70 and above unless I push the my boots hard against the pegs, but doing that makes it quite tolerable. Haven't had it up to 80 yet to see if it smooths out again, but do plan to test that. Sporties are more manueverable than the big twins but have to work at higher RPMs at those speeds hence the vibration and the way the engine is mounted.
your kind of right , quicker steering and curve carving ability has alot to do with the suspension, rake and maximum lean angle. when you change any of these it changes all the variables. springers dont handle curves as well as sportys and dynas because of there front suspension. if you lower a bike or drop the rear end and alter the lean angle and rake it wont corner near as well as a stock bike or one with a better suspension. I wouldnt bet a superglide rider I could carve crooked roads better than him unless I knew he was new to the game.
Old Apr 6, 2007 | 07:20 PM
MacAttack's Avatar
MacAttack
I have a bit between 50-60, and the bars vibrate at about 70 - though it seemed to smooth out at 75 (I'll have to go try). '07 XL1200R
Old Apr 6, 2007 | 10:02 PM
FloridaDrafter's Avatar
FloridaDrafter
ORIGINAL: dragonfiregirl
any sporty riders have problems with vibration at say 70mph or over?
My 1200R is pretty solid. Has a slight vibration around 4k RPM, but not so bad you can't see what's in the mirrors. Actually smoother than my metric Cruiser.
-FD
HogSmoker
Sep 1, 2015 06:58 AM
steambc
Jan 11, 2015 05:28 AM
HemiOrange
Jan 29, 2014 08:44 PM
screamn1
Jul 6, 2008 06:31 PM
Tucker99
Feb 29, 2008 10:52 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
