Other Devices: MYTUNES instructions
I'm not on my own PC so I can't open it and do a quick run-through with it--so, from memory here's how I use it for tuning spark tables:
-open my tuning 'map' (either PowerVision: WinPV, or SESPro)
-open MY Tune>> set for Spark Knock>> and Power Vision
-copy Spark Tables from WinPV into Spark Tables in MyTune
-from MyTUne, load 'log files' collected while riding with PowerVision.
-in MyTune note new recommended Spark Tables (and various related screens of %change, amount of change, new tables, etc.)
-copy new spark tables from MyTune into spark tables in WinPV
-Send modified 'tune' from WinPV into the PoweVision unit
-flash new tune to bike; and ride gathering more desired data
Hope this helps.
Now the problem is the spark tables.......cant copy and paste........says DATA WILL NOT FIT IN TABLE.....WINPV has 15 map and MYTUNES doesn't...only c&p the 20 to 100 but that still won't fit.......
Along the bottom of the window you have...
- Mode:
- Log Type:
- Map:
- VE Type:
- RPM Limit:
Selecting the right Map will set the right x and y axis to match what you see in Win PV. I have a 2014 softail for example, which is Software Level 358. So I went through a few of the SEST-358xxxx maps until I found a one that matched my Win PV ...bingo!
