Nut size
Old Oct 19, 2014 | 10:42 AM
Veekness's Avatar
Veekness
36 mm is the correct size. I use a 1 7/16"...works fine...no need to overtighten that sucker...if 100 foot pounds is the correct torque, fine and dandy, but I tighten mine down to 'just right' and it works 'just fine'. George's Garage makes a good 36 mm wrench for just that use...it's thin, like it needs to be to get in there...
Old Oct 19, 2014 | 10:52 AM
glcash's Avatar
glcash
Originally Posted by IrishHogtrotter
36mm socket and a 3 foot breaker bar, that sucker is torqued @ over 100 ft/lbs. No way is the tool kit wrench gonna shift it.
Tool kit wrench works fine. I sit on the floor behind the bike, grab both saddlebag support rails, push the wench with my right foot. Works like a charm.
Old Oct 19, 2014 | 11:12 AM
lp's Avatar
lp
+1 same here. Plus you can use the skinny wrench without having to drop the exhaust.
Old Oct 21, 2014 | 02:12 AM
mike5511's Avatar
mike5511
Walnut.
Old Oct 21, 2014 | 09:13 AM
Leftcoaster's Avatar
Leftcoaster
I use my handy metric Crescent wrench - works flawlessly every time.
Old Oct 21, 2014 | 01:41 PM
son of the hounds's Avatar
son of the hounds
Ditto on the skinny wrench and the pushing with the foot.
Old Oct 21, 2014 | 05:30 PM
jdvorchak's Avatar
jdvorchak
FYI 13mm is 1/2 inch and 19 mm is 3/4 inch.
Nick 93
May 11, 2016 03:45 PM
Mikeduke108
Jul 11, 2014 11:33 PM
zrx1200
Apr 26, 2011 02:37 PM
kemosabe2
Jan 20, 2008 11:22 AM
Dan B
Feb 5, 2006 12:41 PM
