maladjusted pushrods
Old Oct 21, 2014 | 02:55 PM
Mike's Avatar
Mike
Originally Posted by UltraNutZ
whole lot of complicated advice here. this is easy stuff guys.. don't over think it.
<snip>..........roll the back tire until exhaust lifter (outer) goes up, then down then intake (inner) goes up then down.....
and that's pretty much the short and long of it. You do this from the right side of the bike so you can observe the pushrods. When the intake side has closed, you're on base circle. You can double check tdc with a chopstick inserted into the sparkplug hole. Rotate the wheel back and forth a couple of inches, using the chopstick to feel how close the piston is to tdc if you like.
You most certainly do not need a dial indicator or any other measuring device to determine tdc, just your eyeballs, and a basic understanding of how your valve timing works.
Old Oct 21, 2014 | 04:35 PM
jamess71's Avatar
jamess71
Great post for installing pushrods.
CookUltraClassic
May 5, 2019 02:00 PM
memphisharley
Engine Mechanical Topics
18
Sep 8, 2018 06:39 PM
Screamin beagle
Aug 3, 2017 05:16 PM
Baddass1999
Jan 30, 2017 06:51 PM
dan61t
Apr 24, 2012 07:24 PM
