Cam install
Old Nov 6, 2014 | 05:52 PM
harleytuner's Avatar
harleytuner
Originally Posted by cmashark
I don't change the oil until I after I have ran the engine. I use assembly lube when installing and want it flushed out.
Chris
Not to get off topic, but have you ever had your bike dyno'd with the combination you are running now? If not and you ever get around Fredericksburg with it i'd be more than happy to make a free HP run for you on my dyno. I'd like to have that run so I can compare the curves with some other cams I have for SE bikes.
Old Nov 6, 2014 | 05:58 PM
UltraNutZ's Avatar
UltraNutZ
Chris
I do the same thing. Install cams, run it for a 50 miles or so and change oil BEFORE I send them off for a dyno.
Old Nov 6, 2014 | 06:30 PM
harleytuner
Probably important to note that you should have a good starting MAP.
Old Nov 6, 2014 | 07:10 PM
cmashark's Avatar
cmashark
I sent you a PM. But no it hasn't been on the dyno.
V/r,
Chris
Old Nov 6, 2014 | 10:14 PM
UltraNutZ's Avatar
UltraNutZ
yep good point HT. It's just a given for guys like you and me. :-)
Old Nov 7, 2014 | 06:49 AM
bosshog919's Avatar
bosshog919
^^^^ yes sir....given....
tar_snake
EVO
101
Nov 24, 2018 05:57 AM
NYCFXDC13
Jun 1, 2013 03:38 PM
jacknthebox
May 21, 2010 08:57 AM
06fxsti
Jul 1, 2009 12:54 PM
baggerman1964
Exhaust System Topics
Mar 18, 2008 10:19 AM
