I'm new to the forum, and HD... I'm attempting to restore a '75 FLH. I am now faced with a clean frame... Before I start bolting things back on. What should I finish the frame with? Is rustoleum paint a good idea?
there are sources such as American Iron Magazine which have a pretty active old bike restoration community - check their website and you can find out exactly the correct paint for your bike
( restoration means like factory correct...rebuild is other than that)
I would NEVER paint a frame of any motorcycle with a spray paint, let alone a Shovelhead. If you choose to paint it versus getting the frame powdercoated, go to a professional auto body paint supplier and get a true automotive paint. A two part urethane or epoxy paint with an actual hardener. Something that can withstand everything that a Shovel will dump on it, like gas and oils. Shovels are Gods gift to man, don't insult one with a spray bomb paintjob. Not even on the frame.
Agree about the spray bomb paint job...very thin paint, doesn't protect much, Rustoleum or not. Either powder coat or use conventional HVLP automotive painting equipment. Either will get the job done quite well. The advantage of the auto painting method is that chips can be easily touched up, and since I'm set up for that, it's my chosen method. Powder coating is second to HVLP for me, but others would disagree; many would agree.
I don't have it written down here but there is an epoxy paint that you can brush on and flows out as good as spray paint. Very rugged and chip resistant. Someone here may know the name or over in the shovelhead forum.
You may be thinking of Hammerite (sp?) I would go with powder coating or HVLP if it were me, but Hammerite is more robust than rattle can.
