bike dies!!
Old Dec 5, 2014 | 03:29 PM
goose136's Avatar
goose136
Default bike dies!!
riding buddy has 01 ultra-glide classic with 57000 miles on It but the problem is in the last week it started dying when you first start out on a ride no set distance bike just dies engine light comes on pull in clutch in hit start switch fires right back up and does not happen again on the ride.
Old Dec 5, 2014 | 04:36 PM
IdahoBobber's Avatar
IdahoBobber
I have a Thundermax tuner and once every 1500-2000 mi it does exactly that
Nobody has a clue but it starts back up and runs fine. Where it is an intermittent problem it is very hard to diagnose
Old Dec 5, 2014 | 04:43 PM
Stiggy's Avatar
Stiggy
Check the tilt sensor and make certain that its working correctly. (Under the left side cover attached to the frame.)
Old Dec 5, 2014 | 04:48 PM
SeaZund's Avatar
SeaZund
possibly the idle control sensor: mine would die after riding at (any) speed, then die when I'd pull up at a stop sign or traffic light.
Old Dec 5, 2014 | 05:07 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Mine will also die. Though only when I'm at 1/4 tank or less. Lower on gas I go, the more it dies. The joys of a flat bottom gas tank.
Old Dec 5, 2014 | 06:07 PM
ironhead3fan's Avatar
ironhead3fan
Mine would do this when I first put my inner fairing back together and I didn't have the connection for the speedo in tight enough.
Old Dec 5, 2014 | 06:29 PM
voodoodrug's Avatar
voodoodrug
theres a lot of good info here but I will take a shot....breaker over heating?
Old Dec 5, 2014 | 10:13 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
My 2000 Ultra started occasionally "shutting off" and once or twice was really hard to start when it got older and around 70,000 or so miles.
I suspected the MM EFI system (which I did have
problems with later on) but as it got worse I took it to the dealer and they discovered that it was the "kill switch" that was causing the problem.
Always check the simple, obvious things first.
Check your battery cables and make sure your battery is fully charged.
FWIW, I install a new battery in my bike every THIRD season.
Old Dec 6, 2014 | 01:35 PM
lt1-xjs's Avatar
lt1-xjs
Mine died for the first time last time out also. I was running 65 on the highway and it just quit. It caught me off guard, twist the throttle nothing, look to change lanes and it just came back on like it never happened. I haven't looked at mine but researched it some. Possibly,
Bad ground, loose battery terminals
Corroded terminals at the circuit breaker or breaker itself that was mentioned. There was a recall on it around '99-'03 or something.
A bad voltage regulator
Bad ignition switch, can clean or replace
Faulty bank angle sensor
All have caused a persons bike to just die and start back up from what I have found anyway.
C&B
Jun 5, 2019 09:13 AM
theCoach
Jun 12, 2018 11:33 AM
07JakeelwoodHD
Sep 27, 2013 07:58 AM
Rickey
Oct 16, 2012 05:56 AM
0flhrci4
Exhaust System Topics
Jul 14, 2012 05:59 PM
