Hydraulic Lifter Problem
Old Dec 10, 2014 | 04:23 PM
Sandcrab's Avatar
Sandcrab
Default Hydraulic Lifter Problem
I am currently in process of changing my lifters and cams because they make too much noise when I start it and takes about 1 mile to get them quiet. They also clatter when I rev engine up as I down shift. So pulled the front two and they looked pretty good to me. Today I pulled the rear cylinder lifters and the inboard one has wear marks on it. Take a look, hope you can see the wear marks. Engine got hot several years ago when stuck in traffic, and started pinging. Had AMSOIL 20W50 synthetic. Changed last year to Mobil 1 20W50 synthetic. The roller just looks scuffed to me in several places. Comments please.
Old Dec 10, 2014 | 04:37 PM
Lowcountry Joe's Avatar
Lowcountry Joe
And what does pinging have to do with oil? Be glad you were running Amsoil. Why you would switch to that other oil is a mystery to me. Change your lifters and your problems should go away.
Old Dec 10, 2014 | 04:39 PM
Captain Itch's Avatar
Captain Itch
Sponsor
How many miles on those lifters ?
__________________
www.Captain-Itch.com
Old Dec 10, 2014 | 04:46 PM
Sandcrab's Avatar
Sandcrab
Default Hydraulic Lifters
I have 48,985 miles on them.
Old Dec 10, 2014 | 04:53 PM
Sandcrab's Avatar
Sandcrab
Default Hydraulic lifters
The engine got really hot on a ride to Philly and we sat on I-95 moving about 3 feet, stop, 3 feet, stop in 100 degree weather. I was with 10 other riders, and my bike was the only one that started pinging. I think that pinging said I was frying my engine, and the oil may or may not have been the problem. At any rate, I started hearing the clatter from the lifters right after that. So I switched oil from AMSOIL to Mobil-1. I am not knocking either oil, just providing info in case it may have a bearing on the wear marks.
Old Dec 10, 2014 | 06:45 PM
just plain john's Avatar
just plain john
What does the cam lobe look like? That lifter is toast.
Old Dec 10, 2014 | 07:24 PM
0ldhippie's Avatar
0ldhippie
Yeah, ya need lifters. Newer Harley lifters SUCK! Chevy lifters are much better are cheaper and work well. What cam ya doing.
Old Dec 10, 2014 | 07:25 PM
mikeman54's Avatar
mikeman54
Lifters were bad on my 2010 Ultra with 36,000 mi. Put the SE lifters in it and put the Amsoil back in it.
Old Dec 10, 2014 | 07:28 PM
DTTJGlide's Avatar
DTTJGlide
I'd change lifters, cams, & inner cam bearings, I'd also suggest an Axtell oil bypass valve, it increases your oil pressure & reduces aeration of the oil. While you're in there check the oil pump to see signs of wear or damage.
Old Dec 11, 2014 | 12:13 AM
Veekness's Avatar
Veekness
I would change them even if they weren't scuffed...in my opinion, HD lifters have always been a weak point. I would use nothing but a very high quality lifter, like S&S, JIMS, Feuling, or equivalent. We're it me, I would also change the pushrods to adjustable ones, and it's a good time to consider cam replacement if you're not happy with what's in there now.
