Mounting Air Horn Compressor in Fairing?
Old Jan 7, 2015 | 06:32 PM
hoethree's Avatar
hoethree
Default Mounting Air Horn Compressor in Fairing?
Would like to put a BMFing airhorn on my StreetGlide and was wondering if anyone has put the air compressor inside the fairing? Is there a DIY anywhere here on the Forum? (Search function no function)
thanks!
Old Jan 7, 2015 | 07:18 PM
Musician's Avatar
Musician
You may want to rethink that because from those that I have seen, they all need an occasional shot of lubricant in the compressor. Not very often, mind you, but still needed.In side the fairing could make that a wee problem.Possibly consider mounting it behind a saddlebag. you can hide the hoses pretty easily, and you have access should you need it. Just a thought.That is where I put mine, with one trumpet on each side. To the casual look, they are invisible, but hit the button? Wakes up those cagers, I'll tell you.
Old Jan 7, 2015 | 07:34 PM
mkguitar's Avatar
mkguitar
you could but...the air compressor should be run via a relay...so extra wiring ( fused) from the battery.
pulling the tank to run the wire is easy easy.
oil? some compressors intake air via a hose- if so a drop of oil in the hose would work if the hose is higher than the compressor.
in the past a ran a horn from howie- it failed pretty quick.
so I bought a HD branded off the classisifeds and it works well- mounts in place of teh stock horn
mike
Old Jan 7, 2015 | 08:15 PM
willryder's Avatar
willryder
I had installed a compressor for my air ride in the fairing but took it out cause i found it to be to noisey.
Old Jan 7, 2015 | 10:55 PM
mkguitar's Avatar
mkguitar
Originally Posted by willryder
...too noisy.
the horn compressor only runs when the horn is operated so...
mike
Old Jan 8, 2015 | 12:01 AM
hoethree's Avatar
hoethree
mike
Mike
I went thru 3 of the Harley air horns, each time my ESP replaced them. The 4th one was a cash refund when the shop could no longer get them. Harley quit selling them. I liked the horn but it was junk. Good luck. An O ring in the compressor fails.
Old Jan 8, 2015 | 03:58 AM
penmaker's Avatar
penmaker
What is the BMFing airhorn? I can't find anything on it. I've got Howards Horns on mine now and I'm not very happy with them
Old Jan 8, 2015 | 06:59 AM
SafetyMan's Avatar
SafetyMan
I didn't read that as a brand... I read it as Big Mother F..ing airhorn...
But I've been wrong before. Quite often in fact.
Old Jan 8, 2015 | 07:01 AM
SafetyMan's Avatar
SafetyMan
I ran 2 compressors on my Heritage, mounted them in the left saddlebag...
Not as easy with hard bags.
I'm thinking of putting a compressor or 2 in the left lower.
Old Jan 8, 2015 | 09:01 AM
hoethree's Avatar
hoethree
Yessir! Correct!
