Battery
Old Feb 3, 2015 | 10:58 AM
slammed05fatty's Avatar
slammed05fatty
Default Battery
did a search on here and found some info, shopping batteries for spring to replace my weak RG battery. found few options, which of these would be best bang for the buck?
Big Crank ETX30L Battery - 400 CCA $100
ThrottleX Batteries - HDX30L 400 CCA $ 109
Yuasa (YUAM723HL) GYZ32HL Factory Activated Battery 500 CCA $153
from what i can see these are compatible with my application. if somebody has better option please share.
Old Feb 3, 2015 | 11:01 AM
deano360's Avatar
deano360
check out batteries plus, or walmart, you should be able to save a few bucks, and the batteries plus batteries are made by the same company as the harley ones
Old Feb 3, 2015 | 11:04 AM
mkguitar's Avatar
mkguitar
many of us use the big crank....about $100 to your door
batterymart, they also sell thru amazon...I used my points
Mike
Old Feb 3, 2015 | 11:05 AM
slammed05fatty
i have friends that have went those routes and they just dont seem to last more than a yr or 2, just wondering if there is a better longer term option. or are all the batteries usually start to go after a yr or 2?
edited to include the big crank, i messed up the copy and paste in the OP lol
Old Feb 3, 2015 | 11:07 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Big Crank form Batteries Plus is what I use. Just got one $99 to my door. I'll bet it lasts longer than the stock one too.
Old Feb 3, 2015 | 11:11 AM
Buelligan666's Avatar
Buelligan666
I put a Throttle X in. It's made by East Penn Manufacturing. Same as Harley OEM Deka etc. DO NOT buy batteries at Wally World. If you have a warranty issue and no receipt you're SOL. (don't get me started on that). I bought mine through Amazon. Had it in a day or two.
Old Feb 3, 2015 | 09:03 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
throttle x, big crank and harley are all made by deka.
Old Feb 3, 2015 | 09:18 PM
shineola's Avatar
shineola
I only run DEKA batteries in my bikes....... Quality product
Old Feb 3, 2015 | 09:27 PM
cptdenny's Avatar
cptdenny
My OEM battery only lasted 35 months. I went for the Mega Crank $81.95 to my door with Internet coupon.
Old Feb 4, 2015 | 06:10 AM
chevele72's Avatar
chevele72
I got the Deka from NAPA for $106. That thing cranks the bike without the compression releases. The HD battery wouldn't when it was new. (I still use the CR though) = )
