2014 street glide
http://brukus.com/cgi-bin/p/awtp-pro...parts&pc=12995
Crown Bolt #43228 speed nut (SMS type U 5/16-18 thread )
Crown Bolt #66808 wing bolt ( 5/16-18 thread X 1" ) if you don't want a wing bolt, then use a bolt
a couple of rubber fender washers too, or reuse the stock ones
if theft is prime mover, replace the 1/4" bolt of the FRONT saddlebag mount with a button head type which cannot easily be turned out with visegrips ( on the rt in pic)
I am using one of these each side, with the dzus fastener for ease and speed.
I have had the dzus back out on washboard roads, so the 1 bolt gives some security for that
mike
I would think after enough time and use the rubber might even degrade enough where you could loose the springy qualities that locks the pin in place.
