HD Garage Door Opener
Old Sep 15, 2005 | 12:27 AM
mooks005's Avatar
mooks005
Default HD Garage Door Opener
Anyone try the HD garage door opener kit (the transmitter intalls in the hi/lo beam circuit on the bike and the receiver is hard wired to the door opener). It works, but the other door openers don't work as well due to interference. Curious if anyone has experimented with receiver location?
Old Sep 15, 2005 | 12:58 AM
Birch's Avatar
Birch
Default RE: HD Garage Door Opener
I was wondering is this opener hard to hook up,
Old Sep 15, 2005 | 01:07 AM
mooks005's Avatar
mooks005
I had the dealer install the transmitter. The receiver was easy to install.
Old Sep 15, 2005 | 06:02 AM
pointswhat's Avatar
pointswhat
I've had it on both my bikes. Its a breeze to install and works well, better than my normal remotes. It uses the rolling code technology so security isn't an issue for that and if you leave your bikeoutside they would have to turn it on to activate the opener unlike some of the other do it yourself options out there. You can also buy multiple recievers to use it on more than one door. Also it looks like the reciever can use up to 8 devices if you wanted to add a keypad or other remotes.
Old Sep 15, 2005 | 04:21 PM
screamn_eagle's Avatar
screamn_eagle
my bike came standard with it....i absolutly love it. i give it 5 out of 5 stars...if you got an electric garage door you will love the HD elec garage door opener....its a must have worth every penny...[sm=bounceybounce.gif][sm=goodidea.gif][sm=happy046.gif][sm=smiley20.gif] im sure you get the point.
Old Sep 15, 2005 | 08:06 PM
mooks005's Avatar
mooks005
Did either of you have a problem with interference with your other remotes/loss of range? I also find it to be sensitive to how quickly the hi/lo beam switch is cycled.
Old Sep 15, 2005 | 09:32 PM
Flying Ace's Avatar
Flying Ace
No problems here. Have it on both bikes and the range is great!
Old Sep 15, 2005 | 10:38 PM
Birch's Avatar
Birch
My new bike is comming with one, is it hard to wire to your electric garage door openner or is there any tricks to it.
Thanks all
Old Sep 15, 2005 | 11:37 PM
toadmanor's Avatar
toadmanor
Forget the HD one and try motofx.com.
It is the same principle for SIGNIFICANTLY less than the HD model. Although it does not have the Bar and Shield logo, for which you pay about $50!!!!!
Simple to install, about 30-45 minutes. My dealer wanted $300 to install the one with the bar and shield on it.
Oh by the way the transmitter, which has the bar and shield, will be hidden under you seat or fairing so no one will even know of your sins.
Old Sep 16, 2005 | 01:56 AM
KenM's Avatar
KenM
I use a Liftmaster remote that is designed to go on a key chain. Three button and I have it on a ring with my key. I clevis hook them to my belt and open the door as I come down the street.
Most openers should have a small remote like this for less than 50$
soonerp
Milwaukee Eight (M8)
Apr 13, 2018 09:21 AM
penmaker
Mar 27, 2015 11:57 AM
captbom1
Jul 16, 2012 03:28 PM
2007harleyman
General Topics/Tech Tips
May 10, 2012 04:37 AM
NCTim
Jan 27, 2010 08:34 PM
