Question???
Old Feb 27, 2015 | 03:57 PM
cyclgoat's Avatar
cyclgoat
Exclamation Question???
I have a 2009 FLHTCU and wondering what type of seal is at the shifter shaft, behind the inner primary? I realize i have to take off the outer and inner primary, all the inerds of course, but just want to know what type of seal. Any help will do.
Old Feb 27, 2015 | 03:59 PM
Don81's Avatar
Don81
It's just a little baby seal.
Old Feb 27, 2015 | 04:40 PM
cyclgoat's Avatar
cyclgoat
do i have to take the shaft out?
Old Feb 27, 2015 | 05:09 PM
Moe55's Avatar
Moe55
You do not have to take the shaft out. Cover the splines of the shaft before sliding the new seal over it.
Old Feb 27, 2015 | 05:40 PM
lp's Avatar
lp
Epic.... lol
Old Feb 28, 2015 | 07:54 AM
GTK's Avatar
GTK
It pays to have a shop manual,then you don't have to ask.
Old Feb 28, 2015 | 09:04 AM
rkidd's Avatar
rkidd
Just replaced mine on my 2003. To remove old seal I drilled small hole in the old seal and installed a screw with the sharp end ground off and a wide shoulder on it being careful not to go to deep. I then used a door panel removal tool and a block of wood behind it to pry the old seal out. Then use proper size deep socket and install new seal. Make sure to Loctite shifter arm bolt when reinstalling. Mine had come loose and wore and would not tighten up. Replaced arm with a Baker truss style shift arm. Nice quality piece.
Volant1006
Jun 3, 2016 12:31 PM
Ricketts
Dec 24, 2014 11:15 AM
roaddog
Nov 28, 2011 05:03 PM
Trippster
Jun 8, 2011 08:52 AM
Robtarra39
May 7, 2011 07:12 PM
