hey all, friend of mine runs a sporty right now, it cam with a 95 big bore kit, but not installed, now he just pick up an 06 RG , with a stock 88. will the big bore kit he already has work on the RG?
Do you mean he has a Sportster? I haven't heard of a big bore kit that size, so if the kit he has is 95" it is for a big twin TC88, which should fit his '06 RG. I don't think any big bore kit for a Sportster will fit a big twin.
thanks
I've used the "Big Bore" sporty kits to take 'em from an 883 to a 1200, but I can honestly say I've never installed (or even seen) a 95" kit for a Sporty. Then again, most of my hobby work is on big twins and almost anything is possible these days with the right parts.
It IS common to take an 88 up to a 95 or 98 with bore kits, so if that's what your friend has then it should be no problem to install on his new bike. He would want to make sure that he has the right cam/headwork/pistons/compression to ensure that everything works well together though...
Just Plain John, yeah after i talked with him, i found his sporty is actually an 883, hnot a 1200 like i thought, so your right. dam getting info from himm can be a pain sometimes....lol
thanks all
Send him directly to here so he can ask his own questions and get direct answers and you get less headaches.
