2014 Streetglide, cruise control not working/lazy throttle
Old May 2, 2015 | 07:18 PM
el_diablo's Avatar
el_diablo
Default 2014 Streetglide, cruise control not working/lazy throttle
I had pulled the whole bike apart, had it sprayed , put it all back together at the house. I just took it for a 10.mile test ride and everything went swell except:
1- cruise control not working.
2-check engine light is on.
3-feels like its down on power and throttle isnt as responsive as it used to be.
I assume 1 and 3 are the cause of the light. I plan on checking my controls and wiring either tonight or in the morning.
Old May 2, 2015 | 09:12 PM
Buelligan666's Avatar
Buelligan666
I'm not sure on the newer bikes, but when I put mine back together after the bar swap, I had a check engine light and weird idle. If I rolled the throttle forward it would drop the rpm's. I pulled the codes using the ignition/trip button method. I don't remember the exact codes, but it was something to do with tps. Anyways I double checked my work. I had 2 wires flipped in the plug for the tps. I must have looked at it wrong when comparing it to the pictures I took before disassembly. Just food for thought. I was dealing with an 11EGC so YMMV.
Old May 14, 2017 | 04:59 PM
IsyRider's Avatar
IsyRider
Hi, I was searching the forum for a similar problems ( all your 3 bullets + Heat Grips wont work either). It is on my '14 Ultra Limited. I checked everything as far as the wiring connections and even pulled the Left hand switch controls wiring with the Heat Grips, which costed me a broken wire that i had to solder with shrink.. so, before i installed everything back I took the chance of testing it outside and am getting the same check engine light and I assume the Heats grips should be turned ON, correct?
The whole project was 10" ape replacement that became a nightmare.
most of the riders that shared opinions on this issue pointed out to the TGS errors. Is there a way to check CODES to display somewhere? w/o having to take it the shop?
thanks, i hope someone gets awake since 2015 noticed this thread was on..
Old May 14, 2017 | 08:37 PM
14GuineaPig's Avatar
14GuineaPig
Hold the odometer/trip reset button down. Turn the key to ON. The odometer readout on the speedometer will say DIAG. Release the reset button. Use the rest button to cycle thru ECM, BCM, ABS etc. Each one will have a Y or N after it. Y means a code is present. Hold the reset button down to see a code & to cycle thru the codes if more than one is present. Read the post below .... excellent info
https://www.fuelmotousa.com/p-29661-...es.html#pcodes
Old May 14, 2017 | 08:47 PM
cncmike's Avatar
cncmike
It feels like the first 1/4" of throttle rotation is dead? Those are the exact symptoms I have when there is a bad connection at the side of the throttle body. I usually push the plug in tighter. Or unplug it and slide the plug in and out a few times to wipe off the pins and get a better connection. When I get home I add some dielectric grease.
Old May 15, 2017 | 11:11 AM
IsyRider's Avatar
IsyRider
yes indeed, excellent info!! I am going to look for codes later on... thanks for sending!
Old May 15, 2017 | 09:30 PM
IsyRider's Avatar
IsyRider
Talking Got it done!
after reading your suggestion this morning, i went ahead and re-assembled all the parts and watching closely when i turn on ignition ****, if check engine light came on. at first it did, and made sure the large connector for the TGS is intact together. apparently, that did it. the check engine never came back on.
I explained all that on separate thread created under Rushmore category to address to other problems i resolved due to some neglect and overlooking.
thanks for the input.
Old May 23, 2017 | 01:58 PM
el_diablo's Avatar
el_diablo
haha i forgot I made this thread. My issue actually turned out to be the throttle (plastic **** in the handlebar) going bad. HD replaced it under warranty and got me back on the road.
Grumppa
May 22, 2013 08:58 PM
09rkpolice
Feb 9, 2013 08:03 PM
buckmc
Jun 14, 2011 06:03 PM
QIKLUV
Jul 29, 2010 09:01 PM
IndyClassic
Nov 16, 2008 06:24 AM
