Help Getting K&N Air Filter Off
Old May 4, 2015 | 10:19 AM
bbrooks1963's Avatar
bbrooks1963
Default Help Getting K&N Air Filter Off
I appreciate anyone's help with an issue I have getting a K&N air filter off my bike. On a ride over the weekend, I heard a rattling noise from the area around my air filter and after looking it over, I found that the bracket inside the air filter was broken loose. I was able to back the screw that holds the cover on by using a screw driver to apply pressure under the cover screw while backing it out. I then took off the 3 screws that I thought were holding the filter to the backing plate, but the filter will not come off the backing plate. I've done everything short of breaking out a hammer. Here's a pic just before I removed the 3 screws that should be holding the cover in place. The kit was a K&N RK-3930 and the filter model is a K&N E-3972. Any suggestion on what to try next are greatly appreciated.
Old May 4, 2015 | 10:46 AM
batman.'s Avatar
batman.
Maybe its just "stuck" from age and not being removed. Try a lil push and pull action. There should only be the three screws in it which you said you removed.
Batman
Old May 4, 2015 | 10:49 AM
DresserDude's Avatar
DresserDude
I still see a bolt in it at 12:00 but actually 6:00 because the picture is upside down
Old May 4, 2015 | 10:58 AM
bbrooks1963
I flipped the pic. Thanks... I have actually removed all three screws that are showing in the pic and the filter will not budge.
Old May 4, 2015 | 11:38 AM
mikelikesbikes's Avatar
mikelikesbikes
There's a saying: If it moves and isn't supposed to, use duct tape. If it isn't suppose to move and does use WD 40. In this case you may want to try that hammer. Seriously, do you have the K&N filter cleaning kit? Can be had at most auto parts stores. Try the spray oil and let it set up a bit. Just may come loose. Sorry but can't be of any more help as I have had Heavy Breather on last couple bikes.
osudvm
Aug 16, 2015 08:19 AM
HDpride74
Jul 31, 2012 09:48 AM
TRS_2000FLHRCI
Exhaust System Topics
Dec 5, 2008 12:09 PM
so165
Jan 7, 2007 11:17 AM
Gromit
Mar 11, 2006 05:55 PM
