TSSM issue? Not the typical problem
Old May 23, 2015 | 08:41 PM
MIKE93SVT's Avatar
MIKE93SVT
Default TSSM issue? Not the typical problem
So I used a 2002 Road King main harness for a carb bike on my custom build. The harness doesn't know which motor its running and it doesn't matter.
Initially the signals worked like normal and there were no issues. Today I took off on the bikes first real ride outside the usual 3 mile radius.
Afrer about 30 minutes he turn signal indicators stayed on constant. The buttons didn't do anything. So I pulled over after a bit to check it out. Bad idea.
Turned the ignition off and the indicator lights stayed on. Cycled the switch and no change. Tried to start it and the button did nothing. Took a little thinking and the TSSM immediately came to mind. I think it's trying to flash the 4 ways to indicate the fob isn't close and cutting power to the ignition switch.
The TSSM is part number 68922-00B. I'm not sure if it's a security system module or if it really matters. I used a piece of wire and jumped the starter off the power cable and the bike fired right up. I headed home to diagnose.
I disconnected the battery and cycled the power. Hooked back up and no change, indicator lights on. So I unhooked the TSSM and they finally turned off. This is definately the problem.
Long story is... What module part number won't have the security system built in and compatible with the 02 King harness?
Thanks
Mike
confusedscot
Jul 21, 2018 12:18 PM
04lowrider_21
Jul 4, 2017 03:47 AM
chriswillrise
Sep 20, 2016 12:58 PM
tomkost
Aug 29, 2015 02:04 AM
gallensworth
Aug 7, 2011 03:58 PM
