Thought I would post this to see if anyone else has had a similar issue.
2012 Street Glide - Stage one- Power Vision, S and S power tune duals, FM Air Cleaner, VH Hi-Output slip-ons.
Bike runs fine MOST of the time. Every now and then it will jump up in idle speed to around 1200-1300- then it will act like it is running out of gas; If I give it throttle I can keep it running if I keep the rpm's above 2,000. It will pop and sputter but, as long a I keep giving it throttle I can keep it running. After a few of these "spells" it will clear up. It also does this at hwy speeds too. I can be cruising at say 70mph and it "cut out" - loose power, if I give it throttle and keep it above say 2500-3000 rpm's I can keep it running until the "spell" clears.
I have had my indie look at it and he could find no issue- it is an intermittent problem and didn't act up on him. It is not throwing any codes.
I have re-flashed the ecm with the original FM program. I have replaced the fuel filter. I have cleaned the throttle body with sea foam spray- this seemed to clear the problem up for a couple of months. It has come back as of yesterday.
Any ideas? I am thinking I may need to remove the throttle body and dis-assemble and clean? Anyone else experienced anything like this?
Oh- I have also unplugged the connector to the throttle body and added Di-electric grease- did this to the ECM connector as well.
1. broken wire somewhere under the tank
2. fuel injectors bad (not likely)
3. dirty/bad TMAP sensor
4. bad engine temp sensor (not likely)
I had an intermitted issue and finally took it to a dealer. They ended up running the bike with the tank off, wiggling all the wires to/from the engine components/ECM and it ended up being a broken wire to a fuel injector.
Thanks for the replies guys. Yes. I do buy my fuel at the same place.
May give fuel moto a call. After researching some .....seems like it could be the ETS. The symptoms are identical to what others have had when it was the ETS. I believe the sensor is around 30$. May give it a try.
May also want to clean that dilectric grease off. I just had an issue wth my led lights in my rear fender. The brake lights got stuck on and i tracked it down to the dilectric grease in the plug from the main harness to the jumper wires. Once i cleaned that junk out everything seems to work as it should
