CB Not Working
Old Jun 3, 2015 | 08:08 PM
Ultra Pearl's Avatar
Ultra Pearl
Default CB Not Working
Just bought two HD communicators for my 08 Ultra. The intercom works great but I can't get the Cb to work. It won't transmit or receive not matter what I do, any suggestions?
Old Jun 3, 2015 | 08:52 PM
rmc115's Avatar
rmc115
Make sure it is turned on. hit the com button the look at top left of screen for on/off. really need the operators manual. Mike
Old Jun 3, 2015 | 08:56 PM
VineRider's Avatar
VineRider
Also be sure that the squelch is not turned up too high
Old Jun 3, 2015 | 10:00 PM
Ultra Pearl
Jeez..it's turned on
squelch is about half or less.
Hit ppt and you can hear yourself in the headset but the next bike can't receive me, and I can't receive him.
Old Jun 4, 2015 | 07:14 AM
billnourse's Avatar
billnourse
If you can hear yourself the unit is probably broadcasting. Make sure that the bike you are trying to contact has all his stuff set right.
Bill
Old Jun 4, 2015 | 07:17 AM
VineRider's Avatar
VineRider
It may be a problem with your unit then. The only thing I can think of is to check the CB antenna and make sure it is connected to the radio unit. Also check to see if the fm and CB antennas may be swapped. I think the CB is on the right side.
Old Jun 5, 2015 | 08:05 PM
Ultra Pearl
So I took off outer fairing and checked antenna plug, all good.
Pulled out trunk liner and checked connections there, there may have been a ground issue there. Need another bike to check with.
If that doesn't work, it's probably the cb module.
I have been pricing used units on ebay, my only question is what is the difference in the part numbers? Most of the units have the same number but end in a different letter. 76236-06, 76236-06B, 76236-06C.
New part # is 76416-06C
Old Jun 6, 2015 | 02:57 AM
ultra purple's Avatar
ultra purple
I had the same issue with my unit after installing the gps module and hog tunes amp. I thought I had messed something up pretty bad. Tech advised me to Remove my 50amp fuse on left side of bike and let it reset. Has worked fine ever since. worth a try?
Old Jun 6, 2015 | 09:11 AM
Lowcountry Joe's Avatar
Lowcountry Joe
The chicken band radios on our touring bikes output about 2 to 2.5 watts into a 50 ohm load. The feedline and antenna presents a very inefficient load to the transmitter, reducing usable range. But it will work at short distances. The ground issue is important for the shitty antenna to do it's pitiful thing. Would be nice if you had an rf power meter you could put in line and see what's what. That would tell the story. I bet it's ok, just adjust your squelch to a threshold just above the noise. Then ensure that your buddy has his radio on the same channel and that his squelch is not turned up too much or he won't hear you no matter how close you are.
Here's what the antenna coil looks like inside. There is a little hair-sized wire that connects the coil to the whip and another that connects the coil to the spring base. If the antenna is flexed too much, one or both of these little wires break and the shitty antenna is now worthless. You can see a picture below of what's under the plastic cover on the base of the cb antenna. I now use a Hustler antenna and it's much better.
Old Jun 6, 2015 | 09:37 AM
Afdharley's Avatar
Afdharley
My sq is set at 3 bars. Works fine as near as I can tell but distance is pretty short, like maybe 2 miles. I'm guessing there
