14.up touring swingarm flex
Old Jun 23, 2015 | 08:13 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by el_diablo
For clarification, it happened at 115+mph in a long sweeping turn. (on a closed course) I had no problem recovering but itd be nice to have confidence and stability at such speeds.
Too cool!
I hope to take mine to a track weekend next year. For I'd like to get more comfortable with it at high speeds in turns.
If you'd post some about the event, I'd love to read it!
Old Jun 24, 2015 | 11:05 AM
Joe12RK's Avatar
Joe12RK
so now that they have told you that Harleys shouldn't be ridden fast, are you going to sell it and buy a proper sport touring bike? no? didn't think so... but "Dick from the internet" has to tell you how wrong you are.
It's true, rubber mounted suspension parts aren't going to be as stable as solid mounted, but you can optimize it. Check the rear wheel alignment with string or two 8' florescent tubes. Since you can't redesign the tranny/swingarm bushings, you should do the rear brace. Your front end is better, but check the bearings and install a steering damper if you can find one to fit.
ps the track day company around here (Tony's Track Days) does a "non sportbike day" occasionally for people with baggers and other "slow" bikes to enjoy.
Old Jun 24, 2015 | 12:29 PM
FlaHeatWave's Avatar
FlaHeatWave
Originally Posted by escalade6103
yes they will!
things to check:
tire psi and wear, both
shock psi
neck bearing swing check
wheel bearings
swing arm bushings
motor mounts
i mite be missing something but that would be a good start. there are a bunch of articles on here about it. mine does it around 75 in the sweepers if theres a bump or some thing like that. ive got a progressive tru-trac, ohlins, and new tires but stil does it. my next thing is glide-pro bushings.
Check the items listed above, especially the neck bearings. (I prefer the neck bearings a little tighter than spec.) add, chassis alignment.
Neither of my Baggers wobble, ever, even in high speed Western sweepers at 90 with no hands, always stable as a brick...Your '14 should be too, something is out, it's not swingarm flex...
No add on stabilizers on my bikes.
+1 on GlidePro!
Neither of my Baggers wobbled before GlidePro was installed.
The easy way to check, since you should be under warranty, is have your Dealer do it, just tell them it does it around 70mph, not 115...
ShaZAM
Jul 29, 2012 12:49 AM
electra glide
Oct 20, 2010 01:49 PM
ddm502001
Feb 24, 2010 01:27 PM
billo
Oct 3, 2009 02:49 AM
deweyxl
Sep 1, 2008 11:14 PM
