Engine temp
Old Jul 20, 2015 | 04:32 PM
wscott's Avatar
wscott
Originally Posted by J929626
I have no idea what "normal" is but this is what mine looked like this afternoon:
AAT - 102
IAT - 159.90
Coolant T - 176
HT - 256
This was at 70 mph on the freeway.
Srvc manual for my 09 96" states normal op temp for oil is 230 deg .
230deg oil temp is what my bike used to run at 58-60mph cruise on a 78-80 deg day and oil temp increased pretty quick when hitting just 1 or 2 stoplights in a row or when hitting slower traffic like at 25-30-35mph for a while.
So with that said keep in mind std dino motor oil quickly degrades in its ability to lube/cool/protect a motor at approx 250 deg or more so not much fluff room (only 20 deg) for guys running std dino when HD says 230 deg is normal op oil temp.
Most quality full syn bike oils can handle considerable more heat going to approx 300 deg before it's effectiveness starts to degrade.
Scott
Old Jul 20, 2015 | 04:37 PM
Keithhu's Avatar
Keithhu
230deg oil temp is what my bike used to run at cruise on a 78-80 deg day and oil temp went higher pretty quick when hitting just 1 or 2 stoplights in a row or when hitting slower traffic like at 30-35mph.
So with that in mind keep in mind std dino motor oil quickly degrades in its ability to lube/cool/protect a motor at 250 deg or more so not much fluff room (only 20 deg) for guys running std dino when Hd says 230 deg is normal op oil temp.
Most quality full syn bike oils can handle considerable more heat then std dino going to 300 deg before their effectiveness starts to degrade.
Scott
Are you making a distinction betwee head temperature with oil temperature? At the very least, they are measured in different places, so they will not be the same. I could be wrong but head temperature will always be higher than oil temperature.
Old Jul 20, 2015 | 04:52 PM
J929626's Avatar
J929626
Scott
You do notice that I said nothing about oil temp?
Old Jul 20, 2015 | 05:25 PM
wscott's Avatar
wscott
Well,since your being a pia " You actually didnt say anything about oil or engine temp at all just saying (I have no idea what "normal" is) .
So since you didnt state what NORMAL temp you were talking about weather it be oil or engine temp that why i thought i'd give you what HD stated is NORMAL OIL TEMP which was 230 deg.
And i addressed that in my initial post in this thread here saying right up front (I have oil temp not engine temp) to report on which directly relate to each other ,but by just how much deg for deg oil temp related to engine temp for an air cooled or new water cooled hd motor is i dont know .
But sorry it bothered you so much to have to read & learn something you didnt already know that HD's normal oil temp is 230 deg for an 09 96" twinkie.
At least i am on this site trying to add something of value and arent on here with nothing better to do then busting chops for no good reason like you are.
GEESH!!!!!!/LOL!!!!!
Scott
Old Jul 20, 2015 | 05:29 PM
polbit's Avatar
polbit
Originally Posted by mcmahost
I use a power vision and I set the home screen as engine temp and mpg's. My engine temp at 70mph on a 70 degree day is 250 degrees. If I bump it up to 80mph, my engine temp will climb to 270ish. My question is, are the rest of you getting similar readings on your bikes? 1 up riding.
2011 Road King 103ci, Woods TW777 cams, SYN 3, 2 into 1 pipe, SE air cleaner. The bike has not been dyno tuned. Just a canned map.
Thanks
Sam
Very similar to what I saw on my FP3, before I stopped looking at the temps
Old Aug 14, 2015 | 11:11 PM
wscott's Avatar
wscott
AAT - 102
IAT - 159.90
Coolant T - 176
ET - 223
HT - 256
I see you listed " coolant temp " so you must be comparing a " semi water cooled HD " to air cooled HD's which is kinda like comparing fresh apples to rotten apples.
I say that because because the OP of this thread stated he has a 2011 RK thats not water cooled & your newer " semi water cooled HD" should run a bit cooler on avg in hot conditions then the air cooled HD's of same size in same cond in same outside air temp would without any help from things like wards cooling fans and or an ultracool oil cooler with dual elec cooling fans.
Scott
hemi1300
Jun 13, 2015 11:30 AM
Custom96
2014-2024 Touring Models
13
Jul 30, 2014 08:14 AM
1sweetglide08
Dec 19, 2012 04:41 PM
roadking1893
Mar 9, 2009 10:51 AM
hotwater
Dec 5, 2005 01:08 PM
