diy ceramic coating?
Old Jul 28, 2015 | 12:19 AM
escalade6103's Avatar
escalade6103
Default diy ceramic coating?
i was looking at trying a diy ceramic coating on my head pipe. anyone try this? yeah i know it wont be as good as professional job but wont be as expensive either
Old Jul 28, 2015 | 01:52 AM
Recycled's Avatar
Recycled
I know that there are several guys local to me that are set up with the equipment needed to achieve professional results. They can coat both inside & outside. I would rather pay them to do it right. Otherwise, for a typical hobbyist, it would cost much more to do it yourself, by the time you get the material & equipment for applying and baking it.
I do know that places like Summit sell the coatings but don't know much about them or the results you can achieve using them. Good luck if you try it!
EDIT: Dang, come to think of it, just running the engine would likely bake it on better than an oven.
Old Jul 28, 2015 | 11:12 AM
Coat-This's Avatar
Coat-This
6th Gear
Whats on the pipes currently and what color are you trying to do them in? Also, generally when you're referring to coating pipes, "as good" doesn't exist. They're either coated properly or not....... The "or not" is what becomes expensive to remedy....
Old Jul 28, 2015 | 11:27 AM
Greezey Rider's Avatar
Greezey Rider
Nonsense!
If you sand blast the old finish off of the pipe and make sure it's clean and ready to take a finish, you can achieve perfect, long lasting results with VHT Ceramic Header Paint, I have done it multiple times.
The main thing people screw up is in the surface prep and that is why they wind up with problems.
The owner of the coating shop that I use for powder and ceramic coatings has told me that he is more than impressed with the finish I get on my pipes with header paint and that it is a good inexpensive alternative to having them C/coated.
These pipes were both done with header paint, both are still looking great months later.
I did the pipe in the first photo and another guy here did the T-Header in the second photo 2 years ago.
Old Jul 28, 2015 | 12:45 PM
0ldhippie's Avatar
0ldhippie
I had my mufflers and shields ceramic coated locally for under $100. been holding up great for last couple years. If ya do proper surface prep, have proper gun and oven along with following instructions I see no reason it can't be done. Of course buying the proper equipment really isn't cost effective for a couple sets of headers...
Old Jul 28, 2015 | 12:50 PM
Architect's Avatar
Architect
Had the dual headers, two mufflers and two heat shields Jet Coated for $250. Looks great and no issues. The amount of time the proper surface prep is going to take you (at home) plus the materials I think it would be a wash. For the same money I am OK letting someone else have the fun.
Old Jul 28, 2015 | 05:38 PM
Roadie09's Avatar
Roadie09
I was considering using a duracoat product on my last bike before I sold it, it does not look like it would have been that difficult to apply. They even have a step by step on the website.
http://www.houtsenterprises.net/dur_heat.html
Old Jul 28, 2015 | 08:02 PM
Joe12RK's Avatar
Joe12RK
I tried caramacote on my old FXR - it wasn't anything better than paint - real ceramic coatings do insulate - not that ....
Old Jul 28, 2015 | 11:01 PM
escalade6103
currently just stock. i'd prefer silver. i was looking at the Eastwood inside and out. i dont expect a professional job but i would like some benefit and not just a different color. but yeah i have seen plenty that do the prep right have a good result but that was with paint not ceramic
heavyd1
Jan 5, 2019 12:28 PM
FISM
Jan 24, 2014 03:07 PM
2ropes
Exhaust System Topics
Jun 20, 2012 08:58 PM
a911scanner
May 22, 2008 01:51 PM
barrygreen
Apr 25, 2006 09:12 AM
