SE Comp - 42200064A
Old Sep 2, 2015 | 07:11 AM
SBW Cycles's Avatar
SBW Cycles
Default SE Comp - 42200064A
I am planning on replacing my compensator on my 2011 Street Glide (with 103 Power Pack) this winter. It is my understanding that my 2011 has an early version of the SE Comp. Can anyone confirm if the inner primary needs to come off to replace it? If so, I want to replace any seals or bearings as preventive maintenance.
Old Sep 2, 2015 | 07:23 AM
77Tulsa's Avatar
77Tulsa
No the inner primary does not come off and I wouldn't disturb it for preventative maintenance that could cause problems.
camsmith's Avatar
camsmith
It either has to come off or take a grinder to it...I used it as a good excuse to do the chrome inner. I also got a take off outer from a 2014 and thus skipped the epoxy.
Old Sep 2, 2015 | 07:28 AM
FX4's Avatar
FX4
If your compensator has not failed why replace it? The early SE comp is fine. I have been running it for 30k miles. Just had it apart because of an oil leak and the comp is fine.
Old Sep 2, 2015 | 07:29 AM
lp's Avatar
lp
The inner primary does not have to come off since a 2011 model already has the updated rotor used when converting a 2010 and below model to use a SE comp.
Will need to glue in the oil director to the outer primary cover.
Old Sep 2, 2015 | 07:35 AM
camsmith's Avatar
camsmith
I stand corrected. My old '08 was different but I'm just glad I was fortunate enough to get 60K outta the original comp.
Old Sep 2, 2015 | 08:20 AM
Eunoterpsia's Avatar
Eunoterpsia
I thought I read where earlier versions of the SE Compensator included the rotor?
Old Sep 2, 2015 | 08:48 AM
Weavr99FLHT's Avatar
Weavr99FLHT
40100061 includes rotor for 409.95 for pre-11. OP has 11 so no need for rotor replacement
Old Sep 2, 2015 | 09:07 AM
Eunoterpsia
maybe I'm just too damn tired... What is the purpose of having to purchase a new rotor with the upgrade to the SE Compensator.
I see the 30041-08A Rotor costs basically 100.00)
Old Sep 2, 2015 | 09:15 AM
Weavr99FLHT
Not compatible with older style rotor on pre-11 touring bikes
