MM EFI to CARB Ignition/Map sensor Question
1. Will I need to have a VOES system, or MAP sensor to properly retard ignition?
2. What is the best ignition system to run, and are there some models that eliminate the VOES or MAP, though not sure how that would be possible.
Next, I have both the CAM sensor, AND the Crankshaft Position Sensor. The CAM position sensor, "provides engine phase information to the ECM." It is also non adjustable. I assume the Crankshaft Sensor provides actual timing info to the ECM for proper spark timing. With a new ECM harness created for carb using the schematic, and a new carb ignition system:
3. Can I eliminate the CAM position sensor?
Last, I want to use the existing tank, and intend to remove the fuel filter canister, and all the hoses inside, and then cut off the hard tubing coming up from the supply and return lines. I intend to leave the fuel pump isopod and fuel gauge sender. I will use the PINGEL conversion, and leave all the other guts inside, basically to still provide a fuel gauge. So:
4. Is there anything else I need to pull out, or will it give me problems leaving everything inside?
Just be careful u don't cut into tank side wall. I have used and air debuting tool last time and it was a bunch easer
Been using the ultima ign no problems. Copy of 2000 but 150 bucks
