Stuck with stock windshield?
Old May 7, 2007 | 10:51 PM
curmudgeon's Avatar
curmudgeon
Default RE: Stuck with stock windshield?
I cut mine down. There were a couple of good articles in this forum on how to. The one thing I'd like to add is; chop it down in 1/2" incriments. It's not only about seeing through it, it's also about the way the wind is deflected. I did 1 1/4" and that was a HUGE difference. I would have settled for a big difference.
And no, you can't cut it on the bike. Do it on the work bench.
Old May 7, 2007 | 11:11 PM
iclick's Avatar
iclick
I agree your best bet is the jigsaw or scroll saw. Plan your cut well by cutting a template with paper or thin cardboard to get the position perfect. Tape it to the windshield and take a ride, remembering that if you ride with a backrest it needs to be on the bike, as that will change your eye level. Have it equipped for the application that eye level is most important, like with a loaded Tour Pak installed.
I used a scroll saw and cut my stock windshield down 1½", then did the same when I bought an adjustable windshield, both for my old RK. No sawing yet on the SG's windshields, as the 11" Clearview is perfect for me.
The concrete on your garage floor may be the best sanding medium, as on my last saw job I simply scraped the edge of the windshield on the garage floor to smooth it. It was faster and better than sandpaper, saving lots of elbow grease. Keep the surface moving along the edge so you don't wear a flat spot. This technique was described to me by a BMW owner who has a fetish for windshields, and is continually modifying his.
Old May 8, 2007 | 12:53 AM
Streetrunner's Avatar
Streetrunner
When I purchased my SG, part of the deal was to supply an additional shield which is the 12" you see in my sig. In the summer months I use a 8".
Old May 8, 2007 | 01:53 AM
mrhappy999's Avatar
mrhappy999
ORIGINAL: mp
Go to a glass shop. They can probably cut it right on the bike.....for a lot less than an hour of HD labor.
Ditto. My dad has done this a couple times. Way cheaper.
Old May 8, 2007 | 02:06 AM
SMT's Avatar
SMT
The trick is not the cut...it's the bevel and finish of the edge. Coverthe windshieldwith 3M protective wrap or 2"-3" 3M BLUE painters tapeand take it to your local plasic shop. They will cut, bevel and finish the edge for 50 bucks or less.
Don't use regular masking tape or you will hating life real quick.
Old May 8, 2007 | 10:27 AM
Mokey's Avatar
Mokey
Check out JC whitney. You can get a shorter Windshield for only 79 bucks. You just take your lexan off and replace it
Old May 8, 2007 | 11:37 AM
Dannl's Avatar
Dannl
I had my old soft tail windshield cut down by a glass shop. It cost me $20.00. I had to mark exactly where I wanted it cut, take the shield off and they cut it down and ground the edge smooth.
Old May 8, 2007 | 12:05 PM
Ronjo's Avatar
Ronjo
Ebay my man, Ebay!
Old May 8, 2007 | 02:02 PM
Pastor John's Avatar
Pastor John
You don't need the entire windshield; you can reuse the brackets from your stock shield. HD makes a "mid-low" which is two inches shorter than stock which worked for me. When that one was broken by a bolt that came off a truck that I was following, I replaced it with a Clearview for a few dollars less. It has the added features of a slight grey tint and a recurve at the top of the windshield to deflect the airstream. I really like it!
heavypic
Jul 16, 2017 10:12 PM
Road Star
Dec 9, 2016 01:48 PM
Louie Champan
May 2, 2011 09:59 PM
davep
Apr 14, 2010 08:33 AM
COLOrider
Feb 21, 2007 09:51 AM
