Tech question: rear fender fitment
Old Dec 8, 2015 | 03:31 PM
radudel's Avatar
radudel
Default Tech question: rear fender fitment
Hello!
My simple question is: can be fitted a 2014 EG rear fender on a 2009 EG without any DIY or there are some mods to be done?
Thanks!
Old Dec 8, 2015 | 04:22 PM
mkguitar's Avatar
mkguitar
physically it will fit.
you will have to sort out the wiring- i don;t think it is "plug and play"but the wiring won;t be hard to adapt.
harley uses
black for ground
blue for run light
red/yellow for brake light
brown and violet are turn signals
fender tip and plate light wires may both be black, the wire imprinted is +
by the way I saw your other post- if you have a windscreen which is too tall, it is easy to trim the bottom edge to your desired height.
I use a roto-zip or dremel tool- others have used jigsaws...because the cut edge is hidden it doesn;t have to be pretty
mike
Old Dec 9, 2015 | 05:40 AM
radudel's Avatar
radudel
Thanks for answers. I was thinking about shorten from the bottom but If I remove 2" there is a certain angle at the sides of the windshield that doesn't fit any more with the fairing.
About the fender, I need to know more about the holes and the mounting hardware like the saddlebag quick-detachable system or the backrest for passenger.
Old Jan 20, 2016 | 11:38 PM
Cricket11's Avatar
Cricket11
Harley did not build a road glide in 2014, old model up to 2013, new model in 2015.
Old Jan 31, 2016 | 04:45 AM
radudel's Avatar
radudel
Sorry, my mistake. It was about an EG not RG.
Nobody has done this switch between fenders? Interesting...
Old Feb 15, 2016 | 02:25 AM
radudel's Avatar
radudel
If someone interested I just find out that the rear fender from SG is the same for models from 2009-2016 and is also the same with the EG. Except the lightings holes and the brake/turn light.
FBFletch
Dec 23, 2020 02:17 PM
rusty289
2014-2024 Touring Models
Jul 25, 2018 07:26 AM
fatboy1729
Apr 5, 2014 08:35 AM
XjldX
Aug 3, 2012 05:33 PM
RoadKingCop
Aug 12, 2008 08:02 AM
