Anyone have a problem keeping the plug in their aux jack. I'm running my Nano from the windshield bag plugged into the aux jack with the short Radio Shack cable. I spend more friggin time fiddling around with the plugs because the vibration must loosen them. ShouildI try a new cord? Maybe the plugs will be tighter?
If you are using an angled plug try a straight plug. The straight plug might stick out a bit more, but you should not have a problem with it coming out. If you are using a straight plug try another cord. I only use the aux jack with a cord and straight plug and have never had it come out.
get the cable pasted below from the Integratr IV page at www.jmcorp.com ,,,,,,
gives you a straight plug on one end and an angled job at the other ,,,,,, please let me know how it works out ,,,,, this should solve you connection trouble ,,,,,
I use to go through about 1 every couple months from radio shack untill I got the gold plated ones from the sound guys. I have changed to the auxcell set up now.
The gold plated ones come with a right angle and work much better and don't seem to wear out like the other ones from radio shack. JMHO
