neutral starting switch
Old Jan 29, 2016 | 03:47 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by RKZen
I think many of the non-HD brand bikes have a clutch safety switch. If the bike is in gear and the clutch is not pulled in, the bike will not start. The HD bikes do not have this, at least not in the US. Not sure why the MoCo doesn't have this feature, other than it's not mandated by the Feds.
What your bike doesn't have a is a side stand interlock switch. The International models do though.
The OP's 2003 does not have a clutch interlock; if he hits the starter in gear (clutch not engaged) the bike will jump. It's also hard on the starter.
Old Jan 29, 2016 | 03:49 AM
Campy Roadie
Originally Posted by ds33gt
My 14 sgs and buddies 16 cvo sg must be in neutral to start. Can't just pull in clutch and start in gear.
Indeed a bad clutch interlock switch. A lot of times it's after the owner has changed levers and damaged the switch. Most don't know it's there.
Old Jan 29, 2016 | 07:28 AM
Vernal's Avatar
Vernal
The 2 videos below show how to take off and install the lever properly.
Old Jan 29, 2016 | 09:17 AM
SafetyMan's Avatar
SafetyMan
This "lurching" guys are talking about....
Is it actually starting in gear, or does the bike just nudge forward a bit when the starter is hit?
Trying to nudge forward is caused by the clutch plates sticking a bit, and is different than "starting in gear"
Old Jan 29, 2016 | 09:41 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
My 04 will completely start in gear, with the clutch lever released. The bike will creep forward as the starter motor spins the engine. If the bike is facing downhill, it can spin it fast enough that the engine will start.
My 04 has no clutch switch and no connection between the neutral light and the starter switch. Mine will, in oem correct form, spin the starter and the engine in gear or out, with the clutch pulled in or released. The entire burden of control is on the rider, there are no safeties.
Old Jan 29, 2016 | 10:09 AM
SafetyMan's Avatar
SafetyMan
Sorry, I was referring to the newer bikes that mention lurch, but thank you for the response.
It has been established that 2007 was when the clutch switch was introduced.
Old Apr 17, 2016 | 07:39 PM
Edeezyb's Avatar
Edeezyb
Stage IV
I have a 2013 Heritage Softail, and sometimes it will crank in gear, with clutch pulled in. Sometimes it won't. There is a starter safety switch in the switch housing, behind the clutch lever. If you look in behind the lever, you can see a small domed button. The lever has a tab on the back that contacts the button when pulled back. My lever seems sloppy on its pivot pin. So I just ordered a new pair of chromed levers, and hope that with a better lever it will hit the button on the switch, and solve the problem. If that does not solve it, I will look at ways to improve the contact to that button.
Old Apr 18, 2016 | 03:04 PM
mike_oh's Avatar
mike_oh
2003 bikes will start in gear clutch in or out. Don't know when the safety thing was introduced.
Old Apr 18, 2016 | 06:56 PM
14GuineaPig's Avatar
14GuineaPig
From the 2007 Model Year Technical Forum
Clutch Interlock Switch
• Clutch interlock switch functions as an “or” function with the neutral switch
• Switch verifies if the motorcycle is in neutral and if not, the clutch lever must be disengaged (pulled in) before motorcycle will start
• Excellent feature for new riders
WOLFITZ
14
Aug 19, 2019 01:21 PM
Risky Rick
VRSC Models
Jun 5, 2016 04:46 PM
clarkchriston
May 3, 2013 08:23 PM
jobo3800
Jul 10, 2010 07:26 PM
zubaugh
Mar 15, 2006 09:58 PM
