Neutral Safety Switch
Old Mar 15, 2006 | 03:27 PM
zubaugh's Avatar
zubaugh
Default Neutral Safety Switch
I want to install a neutral safety switch on my 05 Ultra. Has anyone done this and is there a kit available?
If not it looks like it would be fairly simple to put a NO Relay in line with the starter switch and energize it with the Neutral Safety switch.
Seems odd that HD doesn’t have this as standard equipment
Old Mar 15, 2006 | 03:34 PM
Loch's Avatar
Loch
Default RE: Neutral Safety Switch
You might as well add a jiffy stand is down switch too. Then when one fails and your bike doesn’t start you can try and guess which one of them failed.
Sorry, I’m just joking around.
Old Mar 15, 2006 | 03:40 PM
Sammi's Avatar
Sammi
LOL!!!
Sammi
Old Mar 15, 2006 | 03:52 PM
Kess's Avatar
Kess
If you shut it off in gear (and you will) it can be tricky to find neutral unless you can roll the bike and the light does not always come on when you are in neutral - Better to always engage the clutch when starting - I don't trust the light - Every bike I have ever owned I make sure I engage the clutch, start it and then slowy let the clutch out to make sure I am not in gear - Wish I could point you in the right direction but I have not seen this mod done before
Old Mar 15, 2006 | 04:04 PM
lil_gmac2's Avatar
lil_gmac2
It's more of a hassel then a solution. IHMO
Old Mar 15, 2006 | 06:18 PM
Neckball's Avatar
Neckball
This is standard on the Buell Blast. Bike will start but when you let out the clutch it will die.
Not sure about the neutral switch, can't remember all the way back to my Riders Edge course.
Old Mar 15, 2006 | 07:13 PM
Rhubarb's Avatar
Rhubarb
I always park mine in gear. I have never had trouble getting to neutral with the bike off. Running is another matter.
Old Mar 15, 2006 | 09:19 PM
BirchwhiteHD's Avatar
BirchwhiteHD
My EG police has a clutch safety switch,the clutch must be pulled in to start the bike,even in neutral. I always park my bike in gear,before i start it i find neutral,roll it back or forward to be sure,then pull the clutch in,hit the start button. no need for a neutral safety switch here,no power to the starter till the clutch is pulled in.
Old Mar 15, 2006 | 09:58 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
My 03 FLHTPI has or should I say HAD a clutch safety switch. I went to a Magura hydraulic setup, and me HD Guru had to warn me I lost the safety feature. To tell you the truth I am so used to pulling the clutch in to start the jap bikes it is second nature to me.
I have the left side cable clutch control in my toolbox... next time I have a chance I'll check it out and post a pic if the switch. I suppose you could cut the wire for the starter button on the right side, run it across the bike in and out of the FLHTP lever holder then back across the bike to hook back into the starter solonoid wiring.
GittinThere
Jul 10, 2019 02:50 AM
Risky Rick
VRSC Models
Jun 5, 2016 04:46 PM
cajun1957a
Apr 18, 2016 06:56 PM
fffffish
Apr 14, 2016 05:27 AM
clarkchriston
May 3, 2013 08:23 PM
