nitrogen in tires?
Old Jan 31, 2016 | 07:54 PM
daveg2007's Avatar
daveg2007
Stage II
Default nitrogen in tires?
i have a 2007 ultra classic Harley Davidson I was wondering what all you think about putting nitrogen in my tires.. will this keep then cool while riding double?
Old Jan 31, 2016 | 07:57 PM
RollaMo's Avatar
RollaMo
Some people use nitrogen, some don't.
It is a matter of personal preference.
It is like starting an oil thread. Everyone has the perfect solution.
Old Jan 31, 2016 | 07:58 PM
mkguitar's Avatar
mkguitar
nitrogen has larger molecules than 20% of the pump air ( 80% of atmosphere is nitrogen anyways)- those larger molecules are slower to migrate through the rubber- so your inflation stays more stable over a longer period.
nitrogen doesn;t expand like "air" when subjected to heat or changes in elevation*.
which is good- that's why race cars use nitrogen, the tire pressure stays stable lap after lap
I have no idea as to whether your tires will be cooler- overheated tires are often under inflated and the sidewall flex creates heat...and the tire may fail
I took my little tank to costco and the guys filled it for me.
mike
* a casual dayride in AZ can have a 7000' variation in elevation.
Old Jan 31, 2016 | 07:59 PM
lp's Avatar
lp
Leeeets geeeeeeeet rrrreeeeeeeeaaaaaaddddyyyy to ruuuuuummmbllleeee!!!!!
Old Jan 31, 2016 | 08:02 PM
madsonp's Avatar
madsonp
The idea in using N2 is that N2 doesn't expand and contract due to heating and cooling of the tire as much as O2 does, thus resulting in a more constant pressure in the tire, it won't keep your tires running any cooler just because it N2. It's up to you if you want to run it or not, I myself don't think it's worth the hassle.
Old Jan 31, 2016 | 08:07 PM
TSheff's Avatar
TSheff
A HUGE thread already exist on this.
Do whatever you wish. Or perhaps ask the guys at the tire shop or Harley shop if they run nitrogen.
Old Jan 31, 2016 | 08:23 PM
fwb35's Avatar
fwb35
I used nitrogen and most of the teams that I raced against used it as well. A tire is like a spring, more air stiffer, less softer, nitrogen will not change as much as air. If I went out for a ten lap session with air, the tire pressure would go up at least 10lbs, with nitrogen 3 or 4lbs, that makes a big difference in the way the car handles. Nitrogen also does not leak down as quick. It will not make your tires run cooler and you will not notice a handling difference on your bike, but the tires will not leak down as quickly. Is it worth paying for nitrogen in your bike, I would say no, in a race car, yes, just my opinion.
Old Jan 31, 2016 | 09:19 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Its important to remember that nitrogen is exempt from physics and all equations relating to gasses. It is a truly magical material. ;-)
Old Jan 31, 2016 | 09:23 PM
the wild hog's Avatar
the wild hog
You honestly believe it makes that much of a difference?
Old Jan 31, 2016 | 09:24 PM
Brewmany's Avatar
Brewmany
Time for someone to post that photo of the headache guy.
