clutch question
Old Feb 15, 2016 | 02:59 PM
Andrew2500's Avatar
Andrew2500
3rd Gear
Default clutch question
hi everyone quick question
I'm in need of a clutch and this is what I'm looking at
option 1 Barnett xtra plate kevlar with a 480 spring and a clutch wiz
option 2 Barnett xtra plate Kevlar with a spring convertion kit
pro or cons ???
2012 ultra classic 103 95hp 111 tq
Old Feb 15, 2016 | 07:35 PM
dfowler1's Avatar
dfowler1
https://www.hdforums.com/forum/touri...utoclutch.html
Old Feb 15, 2016 | 07:46 PM
qtrracer's Avatar
qtrracer
You don't need anywhere near that kind of spring. Put a fresh stock clutch pack back in, put a SE 380 spring in if you must. Adjusted properly and filled with Formula+ primary fluid you should be more that good.
Old Feb 15, 2016 | 08:29 PM
Andrew2500's Avatar
Andrew2500
3rd Gear
the clutch wiz needs that heavy duty spring to work rt but pulls in like butter the se 380 is harder to pull in then stock that's why I was thinking that route but Barnett says spring convertion is also easier then stock
Old Feb 15, 2016 | 08:48 PM
qtrracer's Avatar
qtrracer
No clutch wiz, LOL!!! Go with stock pack and a 340 spring. You should be fine. Did a '14 with cams,a/c,exhaust, and tuned at 115tq, holds fine. The rushmores have a 340 spring std. You want to spend a bunch of money on a barnett coil spring conversion, im sure it'll work fine but I don't think its needed.
Old Feb 15, 2016 | 09:30 PM
Mirnldi@gmail.com's Avatar
Mirnldi@gmail.com
Before you go buying a new clutch, disassemble and put some sandpaper to your friction disks. Maybe look into a VPC.
Old Feb 18, 2016 | 09:14 PM
Andrew2500's Avatar
Andrew2500
3rd Gear
thanks for the help guys
Old Feb 20, 2016 | 01:00 PM
msocko3's Avatar
msocko3
VPC won't do squat if the torque bites hard below 3,000 - 3,500 rpm, which is where the VPC starts working.
Roadflyer
Oct 13, 2016 09:19 AM
rowle
Dec 20, 2015 11:48 PM
jeffbetrollin
Dec 8, 2015 02:15 PM
DJY
Jul 13, 2013 12:02 PM
Sharkman73
Mar 26, 2013 08:20 PM
