rear shocks leaking??
Old Sep 27, 2005 | 01:51 PM
2006ultra's Avatar
2006ultra
Default rear shocks leaking??
I bought some lowering rear shocks off ebay for the Ultra (used). When I opened the box it was dripping with oil. Both shocks were wet. One shock didn't have a valve in it for the air line but I would'nt think oil would come out of there. Whats wrong with these shocks?
Old Sep 29, 2005 | 12:37 AM
jeepster09's Avatar
jeepster09
Default RE: rear shocks leaking??
Probelly nothing, most shocks will weap if layed on their side. I would not worry about it and use them. Wipe them off and just keep an eye on them for awhile. I have seen this many times and have never seen a problem from it. A brand new set of progressives did this once also.[sm=smiley20.gif]
Old Oct 5, 2005 | 12:03 AM
Mike279's Avatar
Mike279
They do need the plug in them to not leak. I got a set of take offs and they had plugs in but not tight enough. I ended up weighing them to figure how much oil was missing. I used some oil from the old shock to get them the same. If not much leaked out you would be fine. If all the oil leaked out it will ruin the shock. You can use a hand held vacuum pump to refill the shock but they don't sell the oil. Remember to not overfill as the oil will not compress and blow the line off. I used a press to check and the vacuum pump to be sure I did not overfill. Mike
Old Oct 11, 2006 | 07:15 PM
xxxflhrci's Avatar
xxxflhrci
The regular shocks have 340cc of Showa 10 wt suspension oil in them. However, I do not know the correct measurement for the lowering shocks or if it is even different.
Old Oct 12, 2006 | 06:25 AM
screemnjay's Avatar
screemnjay
Put 3 and 1 oil in mine years ago. So far so good
JONNIEROCK
Aug 1, 2019 12:44 PM
row jimmie
Aug 17, 2017 01:00 PM
CharruaHD
Nov 11, 2012 05:19 PM
joe28
EVO
Feb 20, 2011 04:55 PM
cthowards
Jan 7, 2010 10:59 PM
