SE Compensator Question
Old Mar 4, 2016 | 10:24 AM
XMA's Avatar
XMA
Default SE Compensator Question
Getting ready to put my 103 build back together on my 09FLHX and plan to change to the SE Compensator. In doing this do i need to and/or should in change the rotor to the newer style which I think came on the 2011 and later touring models?
Old Mar 4, 2016 | 10:57 AM
LQQK_OUT's Avatar
LQQK_OUT
Yes. Take a look at the instruction sheet (installation, step 8).
http://www.harley-davidson.com/app-c...ts/-J05674.PDF
Old Mar 4, 2016 | 10:58 AM
lp's Avatar
lp
Yes, you'll need the new rotor. HD has a kit that includes it.
Think I got it all from BoardTracker for 240 or something shipped.
You can also just use JB weld to glue the oil thing on. Cheap and just as good (if not better) as the epoxy.
Old Mar 4, 2016 | 02:29 PM
jsbgraphics1's Avatar
jsbgraphics1
5th Gear
This is something I plan to do in the not to distant future, Just to be clear, does the inner primary cover also have to come off to replace the compensator?
Old Mar 4, 2016 | 02:37 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
You can get away with just the outer, I believe, on 2011, and up because it has the "older" SE comp. When I did my 2011, my inner stayed on for the "upgrade" swap.
Old Mar 4, 2016 | 03:12 PM
markwolula's Avatar
markwolula
https://www.youtube.com/watch?v=8zbeXjKMH9Q
With regard removing the inner primary cover,(to make access for rotor removal ),, the guy in the video removed the inner, instead of grinding the outer cover... A little more work and some extra parts,, but a lot cleaner in my opinion... The bike in the video is a 2009 tourer as well...
The SE compensator kit you require for your 2009 bike is 40100061 , (which includes new/ replacement rotor).. The adhesive is sold separately ...
Old Mar 4, 2016 | 04:20 PM
Softy 103's Avatar
Softy 103
Just had a new Baker comp installed in my 2012,decided I would give it a try since so many are having trouble with the SE
Old Mar 4, 2016 | 05:18 PM
Flintshooter54's Avatar
Flintshooter54
Yea I went ahead with the Baker unit as well. Not many miles as I did it in the fall. But the 50 or so miles, there is a big difference compared to the stock 2010 unit. It showed almost no wear, but it sure made noise!
Old Mar 4, 2016 | 05:42 PM
TUCCI's Avatar
TUCCI
Man, if I were you I'd consider putting the Baker compensator in there instead. I've read some real good reviews about it on this forum. I'm sorry to say the HD design blows and wouldn't spend a dime on it even the newest design.
*Road King*
Nov 11, 2018 06:03 PM
SBW Cycles
Sep 6, 2015 03:43 PM
escalade6103
Jun 28, 2015 09:10 AM
DJY
May 19, 2014 07:39 AM
03snake
Dec 10, 2013 08:23 PM
