2015 SG security left me stranded!!
Old Mar 21, 2016 | 08:15 PM
  #31
OKMICK's Avatar
OKMICK
Where exactly were you parked? This happened to me and believe it or not when I got to the dealer that was the first question the tech asked. Told him I was at Home Depot. He said, Yep, something in there interferes with the signal.
Bike fired right up (of course) at the dealer. Tech said it had happened to several people at same location and mentioned another place in town that causes the same condition.
Tech told me had I just rolled it away from the building it would have fired up.
Old Mar 21, 2016 | 09:51 PM
  #32
Twoshots's Avatar
Twoshots
I was parked right at the front door ov CVS pharmacy, but rolled it to the other side of parking lot to push it on to trailer. Also was still not starting when we got it to my buddies funeral home.
Old Mar 22, 2016 | 12:53 AM
  #33
sn95bullitt's Avatar
sn95bullitt
I was planning on having my local HD put the alarm on my new Dyna but after this thread I'm double thinking it.
Old Mar 22, 2016 | 08:23 AM
  #34
RollaMo's Avatar
RollaMo
Not much of a "Tech" if he told you that story.
Even "IF" something was messing with the security signal, entering the over ride code will ALWAYS still work. It completely bypasses the FOB Signal.
Absolutely no reason to have to push the bike anywhere.
Old Mar 22, 2016 | 08:28 AM
  #35
OKMICK's Avatar
OKMICK
No, the override code didn't work either. First thing I tried. Pulled it off the trailer at the dealership and it fired right up. As for Charlie's credentials, he's been at the same dealership for over 20 years and I'd trust him with any type of work.
Old Mar 22, 2016 | 09:00 AM
  #36
hardheaded's Avatar
hardheaded
high tension lines and automatic doors are known to screw with the fob signal, but the over ride should stiil have worked.
Old Mar 22, 2016 | 09:05 AM
  #37
Twoshots's Avatar
Twoshots
Yea Guys, the overide with pin would not pull up. I had the Dealer go through it with me at the store, just to make sure i was doing it right. With the bike armed and without me moving it he went through it with me. Same as what i had tried and would not bring up entry screen for me that day. We entered my PIN and it was working fine at dealer????
Old Mar 22, 2016 | 04:54 PM
  #38
skratch's Avatar
skratch
if you've got a signal that is interfering with your fob, what you have to do is to make sure that your fob is out of the equation. if that means taking the battery out of it, or setting it down 25' away, then do that.
if I have my fob in my pocket, and I try to enter pin override mode, I successfully activate the 4 way flashers. if I take my fob away, and do the same thing, then my bike enters override mode. the problem with interference is that it may be intermittent. keeping you from starting, but still being recognized as nearby....
Mxdad
Jan 29, 2017 06:40 AM
cgtrigg
Mar 3, 2016 01:31 AM
bigmant
Jan 21, 2015 05:10 PM
BarrettsPrivateer
Aug 4, 2014 08:06 PM
stevo.006
Jul 26, 2007 01:23 PM
