So I picked up this 07 SG in last October haven't had it on the dyno yet. This is what it has in it
103" high compression Pistons I think they are 10.5/1 I can start the bike just fine without using the CRV's. Andrews 54H cams high flow A/C and V&H hi flow true duel exhaust.
I think this motor should put out about 95-100hp and 105-110tq at the rear wheel.
How far off do you guys think I am?
Are you putting it on the Dyno for tuning to get it running in the sweet spot,
or just for you to know your numbers the engine is putting out ? ?
A good Dyno man will have your Bike running at it's peck performance over the
entire RPM range. That may not get the highest numbers, but the Bike will run
great all around all the time.
