Misc gray connector (picture attached)
Old Apr 17, 2016 | 10:53 AM
tsneville's Avatar
tsneville
Stage II
Default Misc gray connector (picture attached)
Does anyone know what this is? I've been trying to repair some electronics on my bike, and I found this hanging loose. I can't figure out what it needs to connect to, if anything.
Thanks in advance for your help.
Old Apr 17, 2016 | 11:17 AM
hattitude's Avatar
hattitude
It looks like a touring bike and it looks like it's in front of the battery, that is the Harley B+ connector. You can connect a 12v accessory to it, it is always hot.
I have my Ward's Fans connected to it.......
Old Apr 17, 2016 | 01:18 PM
AlCherry's Avatar
AlCherry
That is correct, sir, yes! That orange one is a purge solenoid connector for Kalifornia models.
Attached Thumbnails Misc gray connector (picture attached)-img_0383.jpg   Misc gray connector (picture attached)-img_0384.jpg
Old Apr 17, 2016 | 02:30 PM
mkguitar's Avatar
mkguitar
On many models ( perhaps all) the B+ does not have a fuse on it excepting the 40Amp maxifuse- consult the wiring diagram.
if you use this add a fuse- a wiring fault on this circuit can kill your bike dead on the road if it blows the maxifuse ( & who carries a maxifuse?)
This same circuit provides power to other things such as:
ECM
abs
Lighting
ign switch.
the purge solenoid circuit also provides power to the fuel injectors and ignition coil...a wiring fault here or voltage drop due to wiring in lights or an amp can cause real driving problems.
Welcome to the Forums
Mike
Old Apr 18, 2016 | 06:01 AM
bigskyroadglide's Avatar
bigskyroadglide
ECM
abs
Lighting
ign switch.
Mike
Mike,
I carry a maxi fuse and a side stand spring. Hard lessons make us prepared
Old Apr 18, 2016 | 02:37 PM
X Iron Butt's Avatar
X Iron Butt
Originally Posted by bigskyroadglide
Mike,
My spare maxifuse is resetable (don't ask I don't remember where I got it. but it was free) and fits nicely next to my spare saddle bag hardware and side stand spring. I have loaned the side stand spring twice.
Navy Mustang
2014-2024 Touring Models
34
Dec 13, 2025 08:48 AM
El Chiguete
Feb 12, 2017 09:20 AM
knightenforcer
Feb 11, 2016 10:22 AM
cavalier2000
Nov 12, 2012 04:26 PM
denalion22
Mar 31, 2011 12:44 PM
