Ape question and help?
Old May 6, 2016 | 01:02 AM
fjimmy123's Avatar
fjimmy123
Default Ape question and help?
I've been having a issue with my apes for about a few month, they keep getting loose and seems to be getting worse so this weekend am going to try the bear can trick to see how it works out..but I have a few questions...
2012 street glide
1- Whats the torque spec for the 4 bolt clamp.
2- do you tighten the front ones towards the light first or the ones toward the tank first.
3- what size allen socket would I need .
I appreciate the help, thanks
jaime
Old May 6, 2016 | 06:26 AM
fjimmy123's Avatar
fjimmy123
anyone
Old May 6, 2016 | 07:48 AM
rdc401's Avatar
rdc401
Use some blue lock tight
Old May 6, 2016 | 08:10 AM
Architect's Avatar
Architect
A- did you change from the two piece clamp to the one piece clamp?? If no, find a cheap one and change it out.
B- if you did and they are still moving, Yaffe makes a clamp with a set screw, it will never move again
Tighten on a diagonal pattern. First snug then go around again and make them tight.
Old May 6, 2016 | 09:30 AM
RaceFace's Avatar
RaceFace
I would change your bushings out to polyurethane bushings while you've got it apart. That will help insure no movement. My 16's moved all over the place until I changed the bushings. Good luck!!
Old May 6, 2016 | 09:46 AM
rk08's Avatar
rk08
Concur with what everyone hs said. If those options do not work, take the shop and have them fish out the problem.
Old May 6, 2016 | 10:11 AM
lefty33's Avatar
lefty33
Just did mine a month ago. Followed instructions from my 2012 Ultra Classic Service Manual as follows. No movement.
- Tighten Handle bar clamp front screws until upper and lower handlebar clamps make contact.
- Tighten clamp rear screws to 16-20 ft-lbs
- Tighten clamp front screws to 16-2- ft-lbs
Hope this helps
Old May 6, 2016 | 09:47 PM
fjimmy123's Avatar
fjimmy123
yes is a single clamp and has the upgraded bushings. I was going to try the bear can trick but I think am just going to order the paul yaff clamp with the set screws... thanks
Old May 6, 2016 | 10:10 PM
uplandpinter's Avatar
uplandpinter
Take the clamp off, use a small punch and hammer to make several marks on the inside of the clamp and even some on the handle bar. Most likely the checkering on your bars is to smooth after they were chromed or painted.
bobbyjoes
2014-2024 Touring Models
Jan 1, 2017 09:41 AM
yandeltx
Aug 12, 2011 06:19 AM
HDGent
Nov 11, 2010 08:47 PM
tekeum
Apr 9, 2010 12:51 AM
rap87
Jul 27, 2006 08:51 AM
