08 ultra classic dragging
Old Jun 4, 2016 | 04:46 AM
Poncho666's Avatar
Poncho666
Stage IV
Default 08 ultra classic dragging
So my bike has been popping a bit and feels like the engine is dragging. I also noticed there has been wet spots on the ground from the battery and the voltage has been kinda high.. The engine and battery light just came on. I read some things on here about its probably my voltage regulator, but would that cause my engine to feel likes it's dragging? The bike has about 41k miles on it.. I also have an issue where if I stop for instance for smokes and go to restart the starter will make a terrible noise and not want to start and I can smell oil but no leaks.. It doesn't happen cold, only after it's been driven
Any help appreciated!
Old Jun 4, 2016 | 06:23 AM
dawg's Avatar
dawg
Original battery? What were/are the codes that you have from the engine light? Original compensator still in the bike?
Old Jun 4, 2016 | 11:54 AM
mkguitar's Avatar
mkguitar
well- the stator can put a drag on the motor.
I'd suggest you need to do comprehensive charging system checks to resolve the problem(s) which you seem to already know about.
once that is done- the "drag" may be fixed too.
or at least we can move on without causing damage to the charging system.
checks are in various stickys
but any voltage above 14.8 means your regulator is bad- this can cause damage to the battery and or stator
hot starts require more power and good connections, just like a chevy or any other car
you need a voltmeter, some time and patience
mike
Old Jun 4, 2016 | 12:03 PM
Olie's Avatar
Olie
Poncho,
DO you have the service manual for your bike? If not, I have it in digital format along with the electrical diagnostic.
Old Jun 4, 2016 | 02:38 PM
Poncho666's Avatar
Poncho666
Stage IV
Yeah the battery on the bike gauge is reading over 15.. I noticed that the same time I noticed the "water" under my bike.. Which I assume is from the battery. I have an extended service thing at cowboy Harley, so I'm gonna take it in, but I would still like to know what's going on since I do prefer to work on my own bike. I'm gonna haul the bike in to prevent any further damage. But my guess,with all of yer input, is its my VR. The "drag" is felt when accelerating or when I let off the throttle it feels like the engine is slowing down way more than it should... Thanks guys this is great!
PacBlue_07
Jun 30, 2018 02:16 PM
dcrowe6
Electrical/Lighting/Alarm
Feb 7, 2015 01:55 PM
green hd
Sep 29, 2013 12:50 PM
Bsod
Jul 4, 2011 01:29 AM
jimbob460
May 10, 2011 03:59 AM
