Are Dresser Duals Catless?
Old Jul 13, 2016 | 07:08 AM
Geezr Glidr's Avatar
Geezr Glidr
Default Are Dresser Duals Catless?
If they are, I might need a little more tuning. Just had Power Duals taken off, and Dresser Duals put on. It's pretty hot on the left side, and I have a little decal popping once in awhile. Dealership put it on the dyno again (briefly) and said it looked pretty good, but I'm wondering if it's running a little lean. Sound like tuning?
Old Jul 13, 2016 | 07:13 AM
Keithhu's Avatar
Keithhu
Its tuning, they are cat-less. But temper your expectations, you have a large twin cam running underneath you.
Generally speaking I wouldnt let a dealer tune my bike, 98% of them couldnt tune a bike to save their lives. There are some exceptions of course, but there is a ton of turn-over at Harley dealerships, and when one guy leaves, its "next guy up" mode.
Old Jul 13, 2016 | 07:23 AM
Geezr Glidr
As I suspected! I didn't have a heat problem with the Power Duals like this. Thanks Keith.
Old Jul 13, 2016 | 10:50 AM
slowrollin's Avatar
slowrollin
They are cat-less and I have a set with about 3K miles on them that I took off my 2015. If you're interested in them, ping me in a PM.
Old Jul 14, 2016 | 08:13 AM
surveybob's Avatar
surveybob
I just put a set on my 16 Limited. They are cat-less and run much cooler. I had the decel pop problem but a quick edit with the FP3 map fixed that.
Old Jul 14, 2016 | 10:33 AM
dyna rider's Avatar
dyna rider
Default Power Duals
So why did you have the power duals taken off ? I had true duals on my bike and it ran very hot so I went for the power duals and it now runs cool and has a lot more low end grunt.
Old Jul 14, 2016 | 01:19 PM
Deuuuce's Avatar
Deuuuce
I have the dresser duals, and Thundermax tuner. I like them alot. I did notice on hot days the mid-frame fairing/shield actually works after buying it based on a recommendation.
SnoRider
Aug 18, 2016 10:34 AM
tech7734
Apr 12, 2015 07:28 AM
leeinmemphis
Jun 26, 2011 05:28 PM
Wookie67
May 14, 2010 10:02 PM
parrothead306
Jun 4, 2008 08:42 AM
