Tuning question
Old Jul 26, 2016 | 07:56 PM
byronk's Avatar
byronk
Default Tuning question
Did a search but not really anything solid came up for my question. I bought a 2004 Road King. When I took the AC cover off I found a Harley K&N stage 1 kit. I just installed some slip-ons and got an almost new Power Commander 3 from a friend of mine that I havent installed yet. Bike runs good but pops through the exhaust when I let off the gas to shift and on decel. My question is when I install the PClll does it matter if the bike had a stage 1 flash from the dealer previously? Thanks for any help.....
Old Jul 26, 2016 | 08:40 PM
TUCCI's Avatar
TUCCI
I doubt it will affect much. If you add 8% (8) at the 0-1750 RPM table you'll eliminate the popping during shifting you mentioned. You may be able to download free maps from the Dyna jet website.
Old Jul 26, 2016 | 08:44 PM
byronk's Avatar
byronk
Yeah I have the CD with all the Maps on it and theres some that seem to match pretty close to what I have. Thanks for the reply.
Old Jul 26, 2016 | 09:26 PM
EG-2006's Avatar
EG-2006
It won't matter to the PC3 if your ecu has the stage 1 download. Some PC3 maps already take that into consideration and some don't. The description of the map should tell you if it is for stock tune ecu or stage 1 download. Try a map each way and see which runs better. The maps will (or might) get you closer to a good tune but there's no substitute for a competent dyno tuner.
Old Jul 27, 2016 | 07:59 AM
byronk's Avatar
byronk
Thanks for the advice. I did notice some had with ECU tune and some didnt. I'll take your advice and try both ways and see what works best, thanks.
Steel Steed
Jul 30, 2011 12:11 PM
SunDevilBiker
Exhaust System Topics
Mar 28, 2011 08:58 AM
07ntrain
Jan 12, 2011 08:57 PM
troop
Apr 1, 2010 10:01 PM
MarkM
15
Jan 26, 2010 05:23 AM
