Oil Leak?
Old Aug 21, 2016 | 06:36 AM
Chuck1's Avatar
Chuck1
Your right Bingee, we went for a 70 ride yesterday and it hadn't even started to run down primary, just wet circle around grommet. So just a nuisance at this point. I'll keep it clean, if that's a pain I'll try and seal it.
Old Aug 21, 2016 | 09:07 AM
6530mask's Avatar
6530mask
Not too difficult job to repair. Get a service manual! Case the work req'd. Get proper tools - impact drive for the outer/inner primary. Yes, the stator needs to be replaced. The comp, clutch and primary drive need to be removed. Be careful of the starter - manually pulling on the pinion will engage it and take off your fingers-lift the neg battery terminal for safety!
Old Aug 21, 2016 | 01:22 PM
Bingee's Avatar
Bingee
There's no need to replace his stator. It's fine. The grommet needs sealing. That's all. BTW replacing a stator is not really an easy job.
Old Aug 21, 2016 | 02:27 PM
6530mask's Avatar
6530mask
Fix it right, u fix it once! U flatter me re: difficulty.
2009rocker
Engine Mechanical Topics
18
Nov 17, 2017 11:03 AM
joewg3
Jan 5, 2015 07:16 AM
Netastophales
Nov 8, 2012 09:10 AM
daharleyrdr
Jan 11, 2009 07:41 AM
wvrider
Apr 13, 2006 02:24 AM
