Outer Primary Cover
Old Sep 14, 2016 | 12:42 PM
DinoM's Avatar
DinoM
My local (independent) shop here helicoiled my '05 EGC about 5 years ago and I haven't had a problem since. 2005s, the drain IS on the outter primary!
I did find a different plug with a magnet and used an O ring. I know it probably shouldn't have worked but it is holding steady. Just have to be REAL careful when loosening and re-tightening that drain plug for fluid changes.
Old Sep 15, 2016 | 11:16 AM
Joe12RK's Avatar
Joe12RK
Originally Posted by RIPSAW
My 2004 has a tapered pipe plug in it. Book says it's an MS, not sure when it got changed.
That is another simple option for the OP - and probably what someone before you did when they stripped the original drain threads.
Old Sep 15, 2016 | 12:24 PM
Jackie Paper's Avatar
Jackie Paper
You could be right. Tapping it for a 3/8 NPT would be a good fit. You may just be able to do it 1/4NPT and would not even have to drill it. Would work if you could find a long pipe plug with an allen wrench hole. That is what is in mine.
Old Sep 15, 2016 | 06:25 PM
maineultraclassic's Avatar
maineultraclassic
I may just pick up a "new" outer cover and go with that. If I can get one for short $$, it would save a lot of headaches.
newjack66
Sep 4, 2014 04:55 PM
laserman2431
Sep 21, 2012 02:24 PM
OneBlackFly
11
Sep 29, 2009 11:51 AM
corona1cal
Sep 13, 2008 01:36 AM
ecoli
Mar 3, 2008 04:36 PM
