36mm socket for rear axle nuts - deep or standard depth impact socket??
I'm about to order online a pair of Sunex 36mm, 1/2" drive, 6pt impact sockets for the rear axle nuts of my '14 RK, for wheel removal/install, and belt tension adjustments.
The socket needs to be ~ 1.1" deep to fully engage the flats of the right-side rear axle nut, which gets torqued to about 100 ft/lbs.
I'd like to use "standard" depth sockets, if possible, when applying that much torque, one-handed, with a torque wrench on the right axle nut, while holding the left axle nut with socket and breaker bar. I'll be using a 1/2" drive breaker bar and torque wrench for rear wheel removal/belt tension adjustments.
I have no plans to use these sockets for any other purpose (auto/truck work).
Will a 'standard' depth 36mm impact socket be deep enough, or should I order a "deep" impact socket as well?
Thanks...
Regards
https://www.amazon.com/Pit-Posse-PP2.../dp/B004MTK39S
I think I paid much less and with 2 you can tension the belt, and torque the rt side ( they have square drive for torque wrench) by yourself- WITH the mufflers in place.
I already had 36 mm sockets in my set, these wrenches are just easier to use for that job- a timesaver
Mike
Mike
mkguitar - Thanks for the info. I had considered buying two of these specialty wrenches for this job. I agree it may make the job a bit easier/faster if you don't want to remove the mufflers, however I expect to add a 2:1 exhaust soon. As such, getting to the rear axle bolts would require removal of just 1 muffler. I prefer the grip/durability/cost of a 6pt. socket over these specialty wrenches, especially when using a torque wrench. Just my personal preference.
I'm curious to know the hardness of the metal used for these specialty wrenches, given they are 12 pt (vs 6pt), and the provision for attaching a torque wrench. How many times have you used them for this job? Are they holding up under the necessary torque specs?
Thanks and regards...
I've been using the flat wrenches for years. I'm currently using the OTC wrench that is similar to Harley's HD-47925 wrench to torque the right side axle nut. Between my friends bikes and my three probably over 100 uses with no issue what so ever. It's a 12pt wrench which allows you to get the wrench into a 90 degree alignment with your torque wrench more easily in order to torque the axle nut.
I can't imagine removing my exhaust every time I need to adjust a belt or change a tire but to each his own i guess. I can probably have the rear wheel off the bike in the time it would take me to remove my exhaust.
In my opinion Harley does a great job at providing tools and instructions to maintain their bikes, the lengths people go to deviate from them is just plain silly.
