Removing primary case - question
Old Oct 28, 2016 | 11:35 AM
Road Star's Avatar
Road Star
@!#$%& I cannot get that jackshaft bolt off. Can't BELIEVE how tight that thing is. WTF?
Old Oct 28, 2016 | 11:40 AM
GTK's Avatar
GTK
Use a impact driver on it.
Old Oct 28, 2016 | 11:48 AM
Road Star's Avatar
Road Star
Finally! geez!
Old Oct 28, 2016 | 12:07 PM
Road Star's Avatar
Road Star
Looks like the Mainshaft seal was leaking..
Old Oct 28, 2016 | 12:38 PM
Buelligan666's Avatar
Buelligan666
Belts go 100k plus. Save your time and money and reuse the belt.
xcbullet's Avatar
xcbullet
you don't need any of those tools unless u want to replace the seal that's in the main gear or change the primary bearing, also if u have impact to break the read loctite on big nut. Just have in gear with two by four in front of rear tire. The rag thing is for the clutch & comp nuts. The seal inside the gear looks ok & bearing.
Old Oct 28, 2016 | 01:15 PM
Road Star's Avatar
Road Star
Have this rock in there... should I leave it alone ? It's been there for the past 20k.
Old Oct 28, 2016 | 01:55 PM
BB59's Avatar
BB59
Change the belt. This one had a rock hole in it for 20K miles also. They always seem to fail in the most remote locations. My buddies did 3,000 miles from home. Three days and a few thousand dollars later he was back on the road with a new belt and a rebuilt transmission.
Old Oct 28, 2016 | 03:35 PM
0lowrider1's Avatar
0lowrider1
looks like the race has walked inward causing your leak on the mainshaft......
Old Oct 28, 2016 | 04:40 PM
Road Star's Avatar
Road Star
You can tell by looking at the bearing and case?
