Removing primary case - question
Old Oct 28, 2016 | 04:53 PM
  #31
xcbullet's Avatar
xcbullet
Yes it's walked in , I didn't see it at first till was pointed out. There should be a gap between race and gear to put puller on. So you will need the puller. Baker has a Utube to bump the shaft to get gap back to get puller on. I didn't have to do that though. If you get the bearing upgrade you don't need the install tool. That's what I did , Baker upgrade bearing, Jim's also makes one that can get from J&p.
Old Oct 28, 2016 | 06:08 PM
  #32
Tarkus60's Avatar
Tarkus60
Watch this vid its a 6 speed swap but good info in here....
Old Oct 28, 2016 | 08:07 PM
  #33
Pothole914's Avatar
Pothole914
Originally Posted by xcbullet
you don't need any of those tools unless u want to replace the seal that's in the main gear or change the primary bearing, also if u have impact to break the read loctite on big nut. Just have in gear with two by four in front of rear tire. The rag thing is for the clutch & comp nuts. The seal inside the gear looks ok & bearing.
Did you put that shift arm on or did it come with it? I see it is a two piece. I found one like it a few days ago on the interweb but, they wanted like $250 for it.
Oooops, wrong poster. HEY ROAD STAR.... LOL
Old Oct 28, 2016 | 08:18 PM
  #34
xcbullet's Avatar
xcbullet
I did the Baker master rebuild kit for 5 speed. If I had it to do over I would get the Baker shift kit & shift paw, then Jim's rebuild kit & primary bearing. I had couple things that didn't go smooth with there kit. My arm was loose once but it tightened up ok, the Baker shift arm is nice though.
Old Oct 28, 2016 | 08:27 PM
  #35
dawg's Avatar
dawg
Shifter shaft seal leak will cause oil to go everywhere as you move down the road and make a mess like that. It's good to change all the seals while you're that far.
Old Oct 28, 2016 | 11:13 PM
  #36
wscott's Avatar
wscott
Originally Posted by Road Star
Since I am this far, it looks like there are some things I "must do" and "should do".
To remove the transmission pulley, will I need to remove the main shaft bearing? if so, I will need a special tool for this? any way around it? Actually, two tools, one to remove and another to install.
Since I am changing the belt, I will need to partially remove the swing arm.
I should replace the starter, especially since it has 50k miles, and I occasionally encounter some knocks when starting.
Replace the necessary seals, gaskets and orings.
So, I need to purchase three tools:
Mainshaft bearing removal tool
Main shaft bearing install tool
Transmission pulley socket
Am I missing anything?
You say:
" I occasionally encounter some knocks when starting. "
Well if by that you mean starter makes a loud knock noise at times when starting thats a sure sign of the compensator going bad.
But a bad starter & or starter drive clutch makes more of a grinding noise then when going bad then a true " knock " or bang noise.
Scott
Old Oct 29, 2016 | 09:46 AM
  #37
Road Star's Avatar
Road Star
yes, I put that on there, mine loosened up a long time ago. I think I paid 199.
Old Oct 29, 2016 | 11:53 AM
  #38
Joe12RK's Avatar
Joe12RK
if you don't have a puller for that race, and without a gap behind it, you'll have a hard time anyway, you can use a grinder to cut the race off the shaft. just work slowly along the top of the race until it is so thin that a blue line appears from the heat. then the race will split when it cools and you hit it lightly with a hammer. then you can just pull it off with your fingers. be careful you don't get too aggressive and grind thru the race.
Old Oct 29, 2016 | 12:05 PM
  #39
Pothole914's Avatar
Pothole914
Brand? Source? Thanks
Old Oct 29, 2016 | 12:16 PM
  #40
Road Star's Avatar
Road Star
http://betterlever.com/better-lever-p-1.html
