Removing primary case - question
Old Oct 30, 2016 | 08:45 PM
  #51
Pothole914's Avatar
Pothole914
Originally Posted by Road Star
Yeah, but with that one you have to remove the priMary. With the Better Lever, you won't need to.
That and, if your shaft is not in real good shape, I don't think it will hold up long. As loose as my shaft lever is, I don't want to get it all apart and THEN find out the shaft is not in good enough shape. I have to pull my primary anyway, the shaft seal is leaking so, there is that. LOL
Old Nov 1, 2016 | 12:38 AM
  #52
Road Star's Avatar
Road Star
When you remove the primary, does it take the tension off your clutch lever/cable?
Oh yeah, of course it does. I just removed the clutch assembly. Duh.
Old Nov 1, 2016 | 12:44 AM
  #53
Guntoter's Avatar
Guntoter
I just bumped into it and realized it's flopping back and forth. Or, is it a coincidence that it just broke?
Yes, without the clutch assembly in place, the rod that goes through the center of the mainshaft has nothing to push against. When you get it back together it will work normal.
Old Nov 1, 2016 | 12:55 AM
  #54
Road Star's Avatar
Road Star
omg, thanks.
don't know what I was thinking.
Old Nov 1, 2016 | 04:30 AM
  #55
grbrown's Avatar
grbrown
Cool
omg, thanks.
Deep breath - count to ten - mmmmmmmmmm
We can do this!
Old Nov 2, 2016 | 12:52 AM
  #56
Road Star's Avatar
Road Star
The dealer sold me AllballsRacing #25-3102 bearing kit, just wanted to make sure this is for the bearing and seal thathe goes in the inner primary cover. Instead of using two snap rings, it uses one with a wider bearing. does this sound right? anyone else ever used this part?
Item #10, 25 and 12.
Old Nov 2, 2016 | 01:35 AM
  #57
03fattyaz's Avatar
03fattyaz
//bookmark//
Old Nov 2, 2016 | 08:29 AM
  #58
xcbullet's Avatar
xcbullet
The Baker one I used still used the snap rings.
Old Nov 2, 2016 | 09:18 AM
  #59
Road Star's Avatar
Road Star
Allballs responded to my email, they confirmed that the kit I have replaces those bearings in the image above. items, 25, 10 and 12.
Old Nov 2, 2016 | 06:35 PM
  #60
Tarkus60's Avatar
Tarkus60
Let us know how that works out for you. I am getting ready to do mine.
