Progressive Monotubes input please.
Old Nov 8, 2016 | 06:08 PM
  #31
wils5150's Avatar
wils5150
had monotubes with 1 clip in my road glide. absolutely hated them way to stiff for me( i weigh 150 pounds) put them in a friend who is 250 he likes them.
Old Nov 8, 2016 | 07:20 PM
  #32
just plain john's Avatar
just plain john
You put them in a friend?
Old Nov 18, 2016 | 11:23 AM
  #33
Buckinfitch's Avatar
Buckinfitch
Having a set of Progressive monotubes (touring 31-2500) with 1 clip installed today, I'm sure it will be a major improvement from the stock crap.
Old Nov 18, 2016 | 08:05 PM
  #34
Budda109's Avatar
Budda109
Being November here in Wisconsin. I just received my AXEO's. Will try to get them installed before the snow falls. I doubt I will be able to test them till next year. Thanks everybody for advise and help. The only issue I see is the weight chart turns for stiffness. That sounds **** like? lol. I am 225 lbs. I float between 210 and 250. Should I set it up for 200 or 250? ???? One or two turns?
Old Nov 19, 2016 | 05:53 AM
  #35
UnaHarlista's Avatar
UnaHarlista
Yea, the part I don't like is that if you don't like the setting, (any brand), you have to tear it down again. It would be nice to get it right the first time around!
Let us know what you try first and how that worked out.
Hmm ... how much do you weigh?
Keep us posted with how that setting worked for you.
Old Nov 19, 2016 | 09:11 AM
  #36
Budda109's Avatar
Budda109
I am 225. I always carry rain gear and a jacket/crap in my tour bags. So maybe another 15 lbs. I think I am going with 200 lbs setting. The only complaint I ever hear about any front suspension is too stiff. The only too soft complaints seem to comes from using stock suspension. Which is crap anyway. Even on the Progressive mono tubes. If all clips are removed, it is good just lowered 1 inch. What would be nice is 1.5 turns. But the flat spot on the shaft for the set screw makes that limited. So its one or two turns.
Old Feb 11, 2017 | 02:35 PM
  #37
GhostRiderFLHTC's Avatar
GhostRiderFLHTC
I got these installed with the 2 spacers and the front end is too stiff. Progressive told me to remove one spacer. Is this a full installation job or is there a way to remove the spacer without having to remove the forks, tire, fender, etc?
Old Feb 11, 2017 | 02:37 PM
  #38
sanman4ever's Avatar
sanman4ever
It's a complete tear down. I had the same issue.
Old Feb 11, 2017 | 02:42 PM
  #39
GhostRiderFLHTC
Thanks! Is the difference worth the effort?
Old Feb 11, 2017 | 02:46 PM
  #40
sanman4ever
Yes absolutely worth the effort. I weight 180lbs and the front end was way to stiff with the two clips.
